Results 1 to 19 of 19
    Dec 05 2008
    TYSONS CORNER, VA
    Can Anyone Tell Me What This Warning Light Means?
    This light came on last night for about 40 mins in the car. When I stopped at the store and drove the car another 30 mins, there was no light. I looked in the manual and online and cannot find this symbol. Can anyone please tell me what this yellow warning light means?
    http://www.flickr.com/photos/33146060@N08/3084075617/
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: Can Anyone Tell Me What This Warning Light Means?
    My guess is that your lights are not properly aligned. But thats my guess
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Registered Member Two Rings
    Sep 20 2008
    colorado
    that happened to me once and never seen it again. now i want to know too.
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by king9988 View Post
    It's a warning light for your adaptive headlights
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    checked in the manual?
    '08 Brilliant Black B7 A4 w/ DTM Conversion Stage 2+ - Sold
    '14 Midnight Blue Allroad Premium Plus w/ Nav & LED Package - Sold
    '13 Ford F150 XLT - Current
    '14 Glacier White Q5 Premium Plus - Current
    '08 Ibis White B7 A4 Titanium Edition Stage 1 - Current
    -Steven
    Established Member Two Rings nycats4's Avatar
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    I got that message like 2-3 times while driving. I think its for automatic headlight sensor.
    Senior Member Three Rings jrok24k's Avatar
    Feb 19 2008
    B7 A4
    dipped headlight warning?
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    no i had the dipped headlight warning last night. It looks different and it says "right dipped headlight"
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Jan 24 2007
    did you check your owner's manual???? i would check that first
    Established Member Two Rings hmmd's Avatar
    Feb 07 2007
    2005.5 A4 2.0T quattro
    el centro, california
    i've gotten that a few times. when it shows up, the lights stop swiveling from side to side when you turn. if you turn the lights off, it usually goes away once you turn them back on. i asked the service guy about it, he said it had to do with my car being lowered, but that would happen even before the car was lowered
    ha haa! dangly parts
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    It's the adaptive headlights like mksap11 said. Your lights won't turn, that's all.
    Jul 10 2008
    Austin, TX
    has anyone figured out why our lights do this or the dipped headlight warning periodically, then stop? My assumption is that it would be a loose groundwire or something. Any ideas? Sorry to thread jack
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    same i had it for like 5 minutes, turned hte car off, turned it on, no error. looked it up - couldnt find it.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Senior Member Two Rings KiddEng's Avatar
    Jan 29 2009
    Jersey
    I just got this warning light as well driving in to work this morning... stopped at a store for 5 mins came back and it did not re-appear. I'll have to wait till night to see if my headlights still turn...
    this icon isn't in the manual, i've been looking through it all morning. The only warning display listed for headlights is "Headlight range control defective" and the symbol has up/down arrows behind the "D" and inside the "D" is an exclamation point.
    '93 Civic Hatch :: 390hp/275ftlbs :: Stolen and Stripped
    '06 Arctic White Avant 6MT :: 034, APR, AWE PowaH :: RS4 Sway / H&R / Bilstein :: Gold/Polished LM reps ::
    Jul 10 2008
    Austin, TX
    its your adaptive headlight sensor. Its not uncommon for it to turn on once or twice and then not see it again for a while
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    I think it means your wheel might fall off if you turn your lights on :P
    Seems like youy figured out your problem with the input of others...another audizine SAVIER. ha
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    WooHoo AUDIZINE!!!!!!!!!!!!
    Sorry had to.
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
