Results 1 to 2 of 2
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    RS4 peeps, where are you tapping off power for subs?....
    sure the battery is in the trunk, but I don't want to screw through the cable joints if there is a close tap off point.
    also for signal too, I was going to use the standard back shelf speaker drive,
    comments / recommendations?
    Ta :)
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: RS4 peeps, where are you tapping off power for subs?....
    if you're talking about for an amp then the smart place to do it would be off the battery. If you choose any other wires in the trunk, any decent sized amp will start blowing fuses. Most subwoofer amplifiers draw around 50 amps. As for a signal wire, the only option you will have is to tap into the speaker wire. When you do this make sure you purchase a module from bestbuy or circuit city that changes speaker wires into a set of RCA outputs. that module make sure that the voltage is lowered to a level that you amplifier can handle. If you dont use one of these you will most likely start frying amps.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
