Results 1 to 16 of 16
    Dec 06 2006
    09 Subaru Outback XT, JD Tractor, EZ Go,
    Middletown, Ohio
    Headlights flicker when ESP/ABS activated.
    Noticed tonight driving in the snow...Had the issue intermittantly but it was an every time thing tonight.
    Any ideas?
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: Headlights flicker when ESP/ABS activated.
    sounds interesting. My guesses are either A) your alternator is weak and with most of the accessories on and then the quick use of power from ABS draws some power and drains the rest of the system.
    B)You have a bad ground or open wire and when the ABS kicks in, it creates a draw on the system that isnt normal.
    Im guessing you see this in your dash lights as well? Does it get worse when you have the stereo and defroster on?
    Aug 06 2008
    Canadia
    you need a new battery
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Maybe you were hitting snow bumps and your bulbs got loose?
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    ground?
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    Quote Originally Posted by MacDaddy View Post
    I have to agree with the above your battery has seen better days. I had the exact same problem when abs or when esp kicked in, in the winter time. I was also using a Odyssey PC-680 basically a lightweight battery for a motorcycle. Whens the last time you change your battery?
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Dec 06 2006
    Middletown, Ohio
    not sure when the battery was replaced last, I would think I would see another symptom though.
    Apr 27 2008
    silver s4
    LI
    Did you hook your car up to a vag-com? Did you test your battery and alternator?
    Dec 06 2006
    Middletown, Ohio
    Quote Originally Posted by haus4 View Post
    Only code I have right now is for the Outside temp sensor. Previous owner felt it was fine to let it dangle and drag so it is toast. I have the new sensor just been too lazy to replace it. Have not tested the battery or alternator. I'll look for a date sticker on the battery.
    Registered Member Two Rings SilverStr33k's Avatar
    Sep 29 2008
    01 B5 S4/STG3+, 03 SVT Focus
    Gurnee, IL
    check the conectors on the back of teh HL housings, then check the conectors to the bulbs inside, i had one fall off last winter
    "One time I left my exhaust open and someone stole my valve springs and my piston rings..."
    Ace of Spades Time Attack club member#1
    I will swap your trim (all of it) for $100!! not a bad deal to save your frustration!
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    it sounds like a complex wiring issue.. do you have any aftermarket electrical things?? boost gauge, other gauges, ghey lights?? lol.
    It sounds like something is crossed or power is being drawn out of it..
    Some people I SWEAR dont even think before they post some of the dumb responses.
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    what does your voltage gauge look like?
    could it just be the ABS vibrating the car making it look like the headlights are flickering?
    Dec 06 2006
    Middletown, Ohio
    In car voltmeter is rock steady at 14. Is there a load reduction relay that is part of those systems anywhere. I do not have a Bently for the car so no wiring schematics.
    As far as aftermarket electrical things. Boost guage. No extra lights, nothing.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    I did some snow brake testing last night, mine flicker slightly when the actual ABS is doing it's thing.
    My battery has a good charge, is less than a year old, and shows all the right readings on the voltmeter.
    In other words, I kind of doubt there really is an issue. I'm guessing the temporary drain is normal.
    Now, if you start noticing other symptoms lining up with a battery drain, or if your headlights flicker over bumps, that might be different.
    Brilliant Black 2001 S4 - 6MT <3
    Aug 06 2008
    Canadia
    instead of spending countless hours testing all kinds of crap, hook a multimeter up to your battery, if its voltage is closer to 11.9 then to 12.7 then its time to replace. batteries only last 2-3 years in these cars because there is so much underhood heat (heat kills batteries). if you want to eliminate any voltage drop, add a capacitor to the electrical system.
    Nov 02 2006
    Western Mass
    Quote Originally Posted by Dr.Duct View Post
    why don't you take your BATTERY OUT! and bring it to autozone to get tested then see weather or not I was wrong. Why would you randomly have some obscure wiring issue out of the blue? I had the same exact issue changed my battery and it was that. Think about it when your ESP is activated abs turns on which uses more draw on the battery thus if your battery was on it's way out it will show when your lights dim when ESP kicks on.
    ...For now
    clicky
