Results 1 to 37 of 37
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    NOW need some REAL help plz :)))
    Here is my original post http://www.audizine.com/forum/showthread.php?t=248704
    So the problem is: car is running lean after a couple of dyno runs.
    Here what me and my mechanic have done so far:
    changed MAF/o2 sensors, checked the spark plugs/dv/ coils/ injectors. Did the fuel pressure test/vacuum leak.
    Than we thought that bad gas caused it (it smelled like a bad gas).
    My tank was almost empty, i got a full tank of 93, drove for about 50 miles but its still running lean.
    Could that be something inside the Engine? Low compression?
    Plz chime in, need some help. Thank You.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: NOW need some REAL help plz :)))
    Also, i changed my fuel filter 2 months ago. Could that be it? But honetly i dont think so cause they did the fuel pressure test...
    AAAAAAAAAAAAAAAAAAAAAAA
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Maybe the fuel pump is on it's way out?....
    789whp
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Fuel pressure test wouldve showed that i guess
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Also, rpms bounce between 800-990 rpms.
    Also, VAGcom shows that car is getting a bit better about 10 seconds after we start it
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Guys, plz chime in!!!
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    I'm just throwing out ideas as you seem at a loss...but maybe check that fuel filter again? Maybe something got messed up in the process....
    789whp
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    ^^^ thank you, i appreciate it. I was thinking about it too. But when mine went bad, it was making weird sounds, not even a CEL
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Could that be a bad valve cover gasket? Or some kind of engine leak? Cause i guess there is much more stress on a car during the dyno then driving at WOT on a hwy
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Check the fuel filter and broken check valves near the back of the intake manifold.
    A cracked valve or hose could allow extra air in and cause a lean condition and a wonky idle
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Ok guys, forgot to tell u something...
    In a summer one of my check valves gone bad, i just replaced it with regular rubbet hose... But i was fine untill the last week...
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Just drove on a hwy and it runs fine, maybe backfires a bit more than usuall.
    Also, my MPG went way LOW, on a full tank it shows me 250 mroe miles to go.
    So im leaning towards vacuum leak again.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Definitely sounds like a vac leak.
    What codes have you pulled from vag?
    Just AKA, if you're getting Multiple Random Misfires,
    it's your MAF.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I think misfires are gone... just running lean
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    NEED 2 answers plz
    1. When u have LOW compression, what are the symptoms of it? I know loss of power, oil on spark plugs, but what else?
    2. If u read over my OP, could that be a bad Valve Cover Gasket?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    More input plz!!!!!!!!!!!!!!!! :)
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Plzzzzzzzzzzzzzzzzzzzzzz
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    buy a red audi.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    ^^ Ok?
    Jan 24 2007
    Do you see any sign of oil coming out from valve cover gasket??
    Is the MAF new or used?? Do you have VAG com??
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    MAF is used one i got from my mechanic...
    Where exaclty is the most common place to look for leaks???
    Jan 24 2007
    Quote Originally Posted by aaaudiprotein View Post
    You sure the MAF is good one?? Just check every section of the valve cover but most week point is where cam shaft seals are & all 4 corner of valve cover.
    I would double check if that MAF sensor is good one.
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    buy a black audi
    by the way, im coming to chicago next friday for the weekend...... u betta be available brotha
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    I would clean your MAF with MAF cleaning spray. Then I would check all of your check valves, anything that looks suspect I would swap it out. Alot of people on here have removed their SAI/EGR system so I bet there are some check valves you could get for cheap if you need to swap them out. While doing all of this I would check every hose again. Also check the torque of your plugs.
    Some fast things and some slow things
    ~Josh~
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    We saw an improvement after that new used MAF. Also, i cleaned my old one with the special spray. But nothing helped.
    Here is a couple of pics i took today where i could see dirty (oil) stuff.
    And videos, i dont why, but the car ran a bit better while taking these videos. Basically when it goes down up to 800rpms it bounces. Today also, rpms stayed at about 1000rpms for a couple of seconds before dropping down more. Same as my old vacuum leak, BUT I CANT FIND ANYTHING!!!
    http://s169.photobucket.com/albums/u...t=MOV00081.flv
    http://s169.photobucket.com/albums/u...t=MOV00080.flv
    http://s169.photobucket.com/albums/u...t=MOV00076.flv
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    wow, that must be a bad ass vaccum leak to have the CEL on all the time... my car threw lean codes, then i replaced all the lines with silicone ones... i had 2 broken lines. also, check the big 3 holed rubber piece on the back of your engine that is connected to the valve cover.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by Turb_Oh_A4 View Post
    thanks, i havent replaced anything, but i listened/touched everything i could.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Also, when car idles for about 5 minutes or so rpms stop bouncing a lot... But during driving in neutral they do bounce more.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Get some brake cleaner and start spraying it around the intake and anything after the MAF to see if it changes anything. Stay away for the coils.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    WILL MAF cleaner be better?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    When u say around... where exactly? And what to look for?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    UPDATE:
    took the car back to my mechanic!!!
    He scanned it again and said that my IDLE was raised up to a 1000rpms and car is asking for 22psi's...
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    alright, $800 bucks after its fixed
    my ecu was messed up, someone set the idle way too high, same with my boost, it was set to 22psi ????????????????!!!!!1
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    "Someone"?? You mean previous owner or some mechanic did so by mistake??
    Is the problem solved now??
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    ^^^ read OP
    i was getting custom tune but after he found out i was misfiring he decided not to do anything yet... apparently something was done :(
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    ^^^ read OP
    i did read the OP and the other thread.
    Good u found out it could have made things worse. However did the tune should refund u for the parts u spent on fixing the problem. They should take some responsibility that is.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by jackyaudi View Post
    long story short again... i dont think i would get anything back from those guys... i signed the paper that if something happens they are not responsible or some shit like that
