NEW AND IMPROVED! Now weighted for smoother shifts and at the same price!
If you desire the ultimate in shifting, the JH Motorsports B5 S4 Solid Linkage Upgrade is the perfect solution. This linkage upgrade replaces the OEM rubber/plastic socket assembly with a steel spherical bearing (similar to what the JHM Solid Shifter does for the OEM shifter box). This will give you a full mechanical race car feel, and eliminates sloppiness allowing you to optimize shifts on the street or at the track. The linkage is most purposeful when used with the JHM Solid Shifter and the JHM Delrin Shifter Stabilizer Bushing, however these parts will compliment any SS kit, including stock shifters.
INCLUDES THE FOLLOWING - JHM Modified OEM shift shaft link (Updated OEM version from a B7 RS4 with weight to aid in shifting ease and performance) ($80 from dealer), JHM Modified Steel Spherical bearing, stainless steel spacers, all hardware, loctite and synthetic grease.
_______________
Combine this product with our shifter and weighted knob and experience the best shifting experience possible.
