Results 1 to 6 of 6
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    center display warning question
    ok so i was driving down the interstate and i was passing a semi so i had it gunned in 5th gear and at about 80mph my car beeped at me (much like when you run real low on gas) and i dont know why...
    well i didnt really think tooo much of it, but later in the drive i was passing another car, going a little slower this time probably 70 but had the peddle pinned this time too and it beeped again
    well i grabbed my cell phone quick and snapped a terrible picture cause i was going fast so my hand wasnt very steady but this is the best i could get
    (my center display is all but shot the way it is so i cant tell what this icon would be)
    i know i know its almost impossible to tell, but does anyone know what this could be from? or maybe be able to decipher what you can of the picture to tell me whats wrong?
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    Re: center display warning question
    Most likely the MPH indicator. It just tells you you are going XX MPH depending on what it is set to.
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
    Sep 22 2008
    Minnesnowta (Roch)
    i dont understand
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    While you are driving your car, if you click the right button (normally used to check the service status while idle) it will engage the speed warning. It basically just chimes when you hit or exceed a certain speed.
    Press and hold it for two seconds and it will go away.
    Veteran Member Three Rings kevin12's Avatar
    Jun 20 2007
    01.5 A4 1.8TQM
    South Jersey
    Yeahhh definitely the mph indicator
    Current:
    17 Ibis White A3 2.0TQ S-Line
    01.5 Santorin Blue A4 1.8TQ 5-Speed
    Uni 1+, XS Power Exhaust, ST Coilovers, Forge DV
    99.5 Laser Red A4 2.8Q Tip Totaled RIP
    01.5 Casa White A4 1.8TQ Tip Current Parts Car
    08 Ibis White A4 2.0TQ Tip S-Line
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Mine was set to 35 when I first bought the car..... very annoying until I found out how to change it.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
