    Established Member Two Rings banger2392t1's Avatar
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Question NEW BUYER/ How do I check for common problems?
    I relaize this is probable in FAQ but its impossible to find anything on how to check for the common problems for the B5 S4, just what they are. Im not a wrench by all means although I know the basics, but keep it simple and outline everything. Thanks for everyone who helps me out.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: NEW BUYER/ How do I check for common problems?
    Quote Originally Posted by banger2392t1 View Post
    its a car with forced induction
    problems seen in order of frequency;
    vacuum leaks
    boost leaks
    failing diverter valves
    turbos failing prematurely
    *all of the above can be prevented with good upkeep and maint*
    n75-boost control valve failing
    axillary water pump failing (plastic inlets crack)
    dash cluster pixels dying
    coil packs go out randomly
    there u have it.
    this has been covered 1232151234231zillion times on this forum
    just hang around and look at the numerous threads created by people like you asking what teh common problems are.
    ps if you dont want to learn how to work on the b5s4 i hope your pockets are deep
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    wtf this is your second thread.
    youre gay
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Also lots of control arms and possibly tie rods. Check those out too.
    And valve cover/cam tensioner gaskets (oil starts to seep out, not a huge job).
    Shopping for a used one, i'd personally be a little concerned if the coolant looked non-pink and/or the oil level is real low etc, but I guess those are more general...just saying.
    Most importantly, have the car scanned for codes and get any EGT's etc dealt with!
    Brilliant Black 2001 S4 - 6MT <3
    Dec 01 2008
    2001 Slvr S4
    Kitchener, ON CA
    Quote Originally Posted by ThirdStrike View Post
    youre gay
    WTF was that all about? My other thread is what can i expect for 10-12 grand ....
