Results 1 to 8 of 8
    Registered Member Two Rings Dannyboy's Avatar
    03 Audi A4 3.0, 1995 Saab Aero
    California
    Another wiper question
    Winter is coming, I'm planning on replacing my wipers. Is there any aero style wiper that will fit our car. I saw someone sells similar style on e-bay (UK). Has anybody tried it, or the ECS one is the only option? Thanks
    Jun 01 2008
    Apopka, FL
    Re: Another wiper question
    Bosch icon is as close as you get without spending a fortune.. They have a clip that covers the end ofthe arm so it simulates the high-end look and they work flawlessly. They go for about $22 a pop. My last ones lasted me almost a year.
    California
    Thanks.
    May 12 2007
    San Diego
    Dang, one year? I thought Aero blades were supposed to last a lot longer than that.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    In SoCal they'll probably dry rot before they wear out. Id have to guess you would get 2-3 years... in the northeast its 1-1.5 years in my experience.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by NOCAN View Post
    I live in VA, the combination of 20-40degree winters and 100+ degree summers does lots of damage not to mention lots of rain anyway. They probaly could have lasted another month or two if you want to rag them out.. but they had began to streak after about a year. which means time to replace for me. I wouldn't think OEM aero blades would be much different or last significantly longer since the blade is probably made from the same kind of material. Wiper blades are cheap enough to be able to replace every year anyway.
    May 12 2007
    San Diego
    Quote Originally Posted by lookaught View Post
    Yup, that's what happened to my last set of blades, came right off one day when I was using them (I definitely let them go a little too long). Lasted about 3 years. Wow, I didn't realize the cold weather had that much of an affect on the blades. Are there any type of synthetic instead of rubber blades that would last longer?
    Jun 01 2008
    Apopka, FL
    nope..
    it's not just the material, the design of the wipers means they loose their tension over time. You don't want the material to be too hard anyway, otherwise you risk scratching up the glass.
