Results 1 to 4 of 4
    Sep 16 2008
    San Jose, CA
    horrible beeping noise!!!
    my car was in an accident. not sure what happened, not sure how it was fixed. ( bought after the accident)
    i assume that something is not lined up correctly because every time the car is started, a beeping noise starts.
    its the type of beeping when the door is not closed
    whats worse is when the headlights are turned on, the beeping now turns into a constant beeeeeeeep. as if the car is flat lineing. this continues for 5 mins before it dies to a steady beep...beep....beep....beep for another min.
    - i really just want to disarm this.
    maybe i can take out the fuse that causes this?- but i dont know where to start
    help please
    Established Member Two Rings Two A's's Avatar
    Sep 19 2008
    3 A4's, 1 Q7, 1 porsche 911
    Cary, NC
    Re: horrible beeping noise!!!
    maybe the sensor that recognizes if the door is shut or open isnt working properly
    The green machine money pit
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    yeah thats probably definitely the door contact switch. On a normal a4 with the headlights on when you open the door you get a steady beep. might new a new one or it was mangled in the accident..idk never messed with it before
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    You know, I have a similar situation. When I start my car I get three beeps, but then it goes away. Not sure if this is normal but I think maybe it started after I crashed my car also it wasn't too bad just a few arms in the front drivers side where damaged but the door started to sag or drop... whatever but I had it fixed but there is still that noise when I start the car.
