Results 1 to 18 of 18
    Apr 25 2007
    '14 Q5 Sline
    Dayton, OH
    can I replace just one tire?
    Ok Its seems like I have really bad luck with this car at the worst time possible. I first had my turbos fail on me 2 months before my wedding... now a rim cracks and destroys my tire right before Christmas... Now I know I really should replace all 4 tires, but money is a little tight right now and I can't really afford to buy all new tires. My tires only have about 6k on them so they're relatively new. what do you think? would I be ok replacing just one? or how bout two?
    Jun 01 2008
    Apopka, FL
    Re: can I replace just one tire?
    You'll be okay. 6k isn't something to worry about.
    Registered Member Two Rings
    Aug 18 2008
    Wrong Island
    replace one but get the same tires as the other 3
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by 1FASTB6S4 View Post
    Good point, you defentaly don't want 1 wheel having more or less traction than the others.
    Apr 25 2007
    '14 Q5 Sline
    Dayton, OH
    I would replace it with the same model tire. and I was thinking about it, it might be closer to about 8-10k on the tires. still ok to replace one? Would it be better if I replace two tires so at least they'll be even? I haven't check thread depth yet. wheel repair shop called and said my tire was no good, so I'm trying to see what my options are. Just want to make sure if I do replace one or two that it doesn't mess up the quattro system
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    What is the speed rating of the tire, cause higher speed rated tires = less tread life warranty. 10k could be half worn. I would then do 2 to be safe.
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    LOL not according to discount tire company those morons think it will ruin your diff
    if i was gonna run different tread tho id run it in the front. theres less tq on those wheels
    Aug 06 2008
    Canadia
    Quote Originally Posted by ThirdStrike View Post
    depending on how worn a tire is, its true, if one wheel is spinning slower than the other the spider gears on the pinion shaft will be constantly spinning, they are only designed to spin when going around a corner, when your going straight they don't move.
    the B5 S4 is like the mafia... there is only one way out!
    Apr 25 2007
    '14 Q5 Sline
    Dayton, OH
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Replace in pairs, or all 4 if needed. But certainly pairs at the least.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Senior Member Three Rings Iosilver's Avatar
    Sep 20 2007
    2001.5 Slow4
    Winter Park
    I feel ya brother. I had the same thing happen to me but without the whole one vagina for the rest of my life thing ( I kid)happen to me. I had a tire blowout on me an I didn't have the spare tire with me on a Sunday by a shop mind you, that didn't have my size tires haha. So two days later my driver side turbo went pooh on me. Good luck, I'd say buy a pair. Check out Discount Tire's Ebay store free shipping and ok price on some tires or AW classifieds
    EMpTy WaLLeT
    STaGe: ToTaLeD
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Try ebay for a used tire...sure there's some risk, but you should be able to find 1, 2 or 4 used - same brand, type, and relative wear - for very little money.
    Stg 2 B5 S4
    Apr 25 2007
    '14 Q5 Sline
    Dayton, OH
    I found a guy that has a pair thats the same model and size. I think I may end up just replacing a pair. HE said there was still about 90-80% tread left. I figured it would be better to do a pair and be on the safe side.
    Jan 11 2007
    Salt Lake City, Utah
    Same problem, but I can't find any Kumho Ecsta 235/35/19's to replace 2 with since they're discontinued. I've got til spring though.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    lot of stupid posts in here. quattro can handle it. put a different tire on it will be fine. Your not going to blow anything. ruin anything etc etc etc.
    If you could afford to replace all four great, or two better I guess, but if all you can do is one, it will be fine.
    The differences in traction will be within the tolerances you can get away with on the quattro on our cars.
    Search AW for the exact numbers and limits of tolerance allowed if you're interested.
    EDit: just remembered, I replaced just one tire a year ago when it got a flat...not even the same tread or brand..no problems to date. Again, search AW for the exact break down of the difference in traction that you can get away with on quattro without creating any problems etc.
    Good luck on the wedding! ANd if you have any doubt at all... GET OUT NOW BEFORE ITS TOO LATE!!!!!!!!!!!!
    Jan 11 2007
    A little different and there may have been many other factors at play here, but there was a TT here locally that had the haldex diff lock up at the track on the straight away and it hit the wall. I think it was running a staggered setup. I've heard as long as they're within 3% of the same rolling diameter then you're all good.
    LOOKING FOR:
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Ellicott City, MD
    I just blew my front left tire on my 04 Ultrasport today so I definitely feel your pain. I tried patching it with no luck. As soon as I inflated it back up it went down again.
    I have ContiExtremeContacts with almost 24k on them so unfortunately I have to replace all four.
    I'm sure that you have already taken care of your tire issue but I'll throw my 2cents in anyways...
    As it was stated above you can get away with replacing one or two but use your better judgment. If the tread depth on the current tires are considerably lower than what the new ones are at you may want to replace all of them.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    you should replace two. you dont neeed all four,
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
