Results 1 to 13 of 13
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Part interchangablility
    Hey i got a friend that bought a semi crashed 98 2.8 a4 and he wants to repair it and wants to know if he can buy used parts for any b5 a4 between 95 and 2001 if those parts are interchangeable....or if you could tell me what year models are interchangeable for the 98 model. Thanks
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Re: Part interchangablility
    The only things that are really different AFAIK are the engine components from 96-98.5, and then from 98.5-01.... As fas as suspension and drivetrain it will all copy over except the spindles/wheel bearing/axles in the front, because at some point in 98 they switched to a bigger wheel bearing.
    Body panels are all going to switch over, he could even get s4 body parts. The newer headlights/tails look a lot better than 98's.
    What parts does he need?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by vtracer20 View Post
    What parts do you need? We have 25+ dismantled A4's here at the shop
    Either PM me, or check out the eBay store for stuff you need.
    Rob
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Apr 14 2008
    Milton VT
    hood, fenders..both sides, blinker lights.. both sides, hood latch and hinges
    frount bumper
    radiator support and driver side rear door....
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    you should be able to grab those off of any year B5 A4. The hoods newer than 99.5 wont have the spray nozzles on the hood, i think that's the only difference...
    because racecar.
    Oct 06 2004
    Minnesota
    frount bumper
    A&P has all of that except for the front bumper. I will check the shop.
    Rob
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Mar 15 2008
    A few Audis
    Independence, MN
    Got an email address? I will put together an estimate/invoice for you
    Rob
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    The only thing you need to be careful of is the doors. The doors changed with the facelift (99.5+) cars. The moldings (body side moldings, knee height) changed. It would look really weird if you didn't have all of them matching.
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by djwimbo View Post
    Right on. Pre 99.5 has smaller trim. We have the parts he requested in the small trim.
    Cheap parts
    Rob
    Apr 14 2008
    Milton VT
    Quote Originally Posted by AP-Specialties View Post
    Rob
    [email protected]
    Mar 15 2008
    A few Audis
    Independence, MN
    Let me put something together. I'll have it to you by tonight
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Cheap parts
    Rob
    I know you know what you're talking about, I just wanted to put it out there for the people that are reading but not the OP.
    Mar 15 2008
    A few Audis
    Independence, MN
    Always helps make things clear
