Results 1 to 20 of 20
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Bas gas millage after Carbonio Intake??
    Please dont bash, this is a serious question. I have searched but since Cabonio is such a used word its pointless searching.
    I installed my intake on Monday, and my car read 170 miles until gas tank is empty. Today is thursday with about 20 miles driven and the car reads 95 miles left until gas tank is empty.
    During install the direction said to take the MAF off the hose and twist it to fit the carbonio ..
    I did not do this i simply twisted the rubber hose a bit to fit. Might this be causing the problem? the tube bends a little so it might be restricting air. IDK
    '08 Brilliant Black B7 A4 w/ DTM Conversion Stage 2+ - Sold
    '14 Midnight Blue Allroad Premium Plus w/ Nav & LED Package - Sold
    '13 Ford F150 XLT - Current
    '14 Glacier White Q5 Premium Plus - Current
    '08 Ibis White B7 A4 Titanium Edition Stage 1 - Current
    -Steven
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: Bas gas millage after Carbonio Intake??
    did you reset your ecu? your maf should be reading different numbers now, due to changes in airflow and perhaps air temp changes.
    i'm not too familiar yet with how this car works, but with all other cars i've had, you need to reset your ecu after changing your intake. your car will need to readjust due to the changes, which is why your gas mileage sucks. give it about 2 full gas tanks, and your car should normalize again.
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    I can't imagine something during the install making that much of a difference unless the hose is really choked off.
    Did you touch the maf element?
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Not that i remeber :(
    -Steven
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    keith i im'd you
    -Steven
    Senior Member Three Rings GhostSquadGarage's Avatar
    Jul 05 2008
    SLR32 \ IS300
    Are the clamps tight so there's no air escaping ? If you have a leak it'd cause that for sure as well as being overchoked or restricted, so it could be either.
    No need to reset ecu.
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    GSG i pmed you guys :)
    -Steven
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    also, the computer on our cars isn't the most accurate device. it uses an algorithm to "guess" how many miles your car will get out of the amount of gas in your tank, based on driving habits, avg speed, etc.
    so if you just got a new intake, and you're flooring it and revving the motor a whole lot to enjoy your new sound, it will calculate into how many more miles you will get out of your tank with your current driving habits. chances are, you're a little bit heavier on the throttle, because your car sounds/feels different. therefore your "miles left" numbers may drop significantly.
    that being said, i would definitely go back and review your install. make sure that hose isn't pinched, and that everything looks like it's hooked up properly.
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    thanks guys i will keep everyone updated :)
    -Steven
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    mine has been the same except that sometimes I goose it to hear the diverter valve open, haha
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    i havnt driven it passed 4k rpm
    -Steven
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    I installed my carbonio intake and that was it....No ecu work because I thought that it wouldn't be necessary. Plus, its the only engine mod i have done...
    Am i wrong? PM me fellas
    -Andrew
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Quote Originally Posted by adub View Post
    no your fine .. are you having MPG issues lol
    -Steven
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    no, you don't need any ecu work. However, since your maf will now have different readings with a new intake, it's generally practice to reset their ecu to force your car to learn and readjust to the new readings.
    again, it's not a required step. your if you didn't reset your ECU, it will adjust in due time.
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    p1nk50ck, thanks for your help you always chime in
    i wish we weren't having problems with the rep or else i would give you some !
    ill keep you updated getting up early morning tomorrow to get this fixed and hopefully buy Monday i should have my turbo inlet pipe
    -Steven
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    fixed it this morning .. i am about to go take a ride with it.. the minute i started my car the dash read 30 more miles left in my tank of gas :)
    -Steven
    Jul 11 2005
    Auburn
    Quote Originally Posted by AWDTURBO View Post
    What was wrong with it?
    Jul 28 2008
    2008 A4 S-Line, 2005 BMW M3
    New Jersey
    If I remember correctly the carbonio instructions said after you install it to letr the car idle for a certain amount time so the car could adjust to the increase in airflow...I actually got better mpg after the intake was put on
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    ok well went to the DMV and to school and back home today, was about 30 miles. Got in the car and it read 125 but i guess when it finally adjusted it went to 115. I am posting now with the dash reading 110. :) everything turned out ok.
    Keith i think the bend in the hose did make a difference.
    Keith thanks for your help and this changes what alot of people said about APR customer service .. He im'd me all of yesterday to try and fix the problem
    -Steven
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    good to know everything worked out.
