Results 1 to 3 of 3
    Established Member Two Rings ajrettke's Avatar
    Sep 25 2005
    Savannah, GA
    Getting satellite radio
    Hey all, I'm looking at getting a sirius radio. I have the phatnoise but it's just a pain in the arse to upload new songs, playlists, etc etc. And I like having randomness for songs.
    Anyway, I was seeing how I could get this setup nice and clean. The only thing I've found that I like is getting the SC-FM1 (starbase FM tuner). I'd mount the unit in the Cd changer/phatnoise spot along with this:
    http://www.crutchfield.com/p_469AUDA...s-AUD-AUX.html
    This way it's a good signal and direct to the head unit. Then running the control unit up just below the center vents.
    My question, would this work well? Is there better/cheaper options? It's hard to find that starbase unit (seems to be discontinued and out of stock everywhere...but I found one site with it). I thought about getting a dock setup but I don't want to deal with 3 cables sticking out of a dock in the center of the car, then splicing into the sense/12/ground lines and running a bunch of wires to the trunk. (not to mention I don't think it would look that good with a dock and control unit sticking out of the dash).
    '02 Silver S4, APR chip, RS4 clutch, ASP DTS, Miltek exuast, Sparco pedals, AWE boost guage, B&M SS, 30% black tint, on 17" flix lex with exclaim UHP's.
    FS now! http://www.audizine.com/classifieds/...ct=9874&cat=30
    Senior Member Two Rings u7401087's Avatar
    Feb 24 2006
    Indiana
    Re: Getting satellite radio
    hm.....
    i used to have XM radio on my car too
    i use fm transmitter mounted on the antenna port which located on the back of the head unit and you will have a wire connect between antenna port to your XM radio (this is your signal cable.....you will also have an antenna wire connect to your XM radio too....).
    the only problem is the sound quality....... since your signal is come through your antenna port instead of direct sound signal port, your sound quality will decrease by using that.....
    RS4 grill~custom widebody~M3 style lip~DTM Kreuz 10
    Dynaudio~Xtant~
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I just have my sirius set up for fm transmission. Not the best, but easy. Either way satellite radio kicks ass!
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
