Results 1 to 6 of 6
    Veteran Member Three Rings B5in's Avatar
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    GIAC flashloader software - where is it?
    I am kooking for the flashloader software that supposedly is free & on GIAC's website for download but I can't find it, does anybody have a link
    TIA
    car in question since everybody likes a nice arse...pic for more clicks:
    C5 AR, B5.5 W8, and a suuuuuper slo mk4
    "If You Work for a Living, Then Why Do You Kill Yourself Working"
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Re: GIAC flashloader software - where is it?
    Quote Originally Posted by giacusa.com
    Flashloader™ is Windows™-based serial reading and writing (flashing) software authored by GIAC using an in-house designed USB flashing cable (supporting both K-line and CAN protocols).
    I do not believe it is free as there is a hardware portion to the product.
    GIAC Flashloader™ software with "Touchless" Installation Now Available!
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Oh I don't want to flash my ECU, I want to change between my 3 GIAC programs via vag-com cable & computer
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    I'm actually looking for that program as well. He isn't looking for the software to flash his ECU, he is looking for the switched that you can put on a computer so that you can hook up a VAG-COM cable and perform the switches without paying like $160 for the handheld switcher.
    (I'm new btw came over from audi forums :) ).
    Apr 05 2006
    This is what you want: The Software Switcher. However I would check compatibility.
    To successfully operate Flashloader™ Software Switcher, you will need GIAC Flashloader™-compatible performance software(K-line cars only), A PC with a Windows™ operating system, and a USB or serial port K-Line compatible communication cable (K-Line enabled Ross-Tech® cables recommended). A laptop is preferable to a desktop PC because of its mobility however a desktop PC will work with an extension cable.
    Click here to download Flashloader Switcher
    for use with 97-99.5 Audi A4 models
    with new GIAC Software
    Software Switcher User Manual
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Hell yes...scot_w You Are Da Man!!!!!!
