Thread: E-brake light.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    E-brake light.
    Ok ive noticed lately that when it very cold out 25deg or so while im driving and go around a right hand corner my brake light on the dash will buzz and blink a few times then go out. It doesn't do it all the time only on occasion i checked the fluid level and its fine. Ive yet to check for codes but wanted to post to see if anyone else had same issue and how did they resolve it.
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    Re: E-brake light.
    sounds like something is up with the brake system. are you sure its not low on brake fluid?
    i had a similar problem with my b6 long ago when the brake light would come on and flash for a little bit, then go away after a minute or two. topped off the brake fluid and all was well. this was around 85k or so miles on it. might be worth it to top off the brake fluid and go from there.
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Nov 16 2007
    Westerly//Providence
    Re: E-brake light.
    had the same problem, didnt notice a pattern with the temperature tho....just top off your hydraulic fluid and it should stop.
    Jan 27 2007
    NC
    Re: E-brake light.
    Hmm i guess ill have to take a closer look at it.
    vizi
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: E-brake light.
    my light would come up every now and then. I checked the fluid but it was still full. Then I checked my pads and found that they were worn down to the sensor which is why my light was coming on.
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
