Results 1 to 6 of 6
    Established Member Two Rings Marios C4's Avatar
    Nov 27 2008
    Michigan
    RS2 MAF ??????????????
    i have a RS2 setup on my car but now for some reason my car idles funny (sometimes almost shuts off while it idles) people from her told me that its my MAF (MAS AIR FLOW SENSOR) because everything else with the car its fine
    and do i need to upgrade my fuel pump with my RS2 setup?????
    Where can i get a RS2 MAF????????
    Established Member Two Rings YODASFRO's Avatar
    Dec 22 2007
    91 200 20v 91 200 20v avant 92 urs4
    Re: RS2 MAF ??????????????
    Is your 02 sensor good? How bout your ISV? I would try to find someone local to you to
    try a known good MAF before buying a new one.
    http://www.motorgeek.com/phpBB2/viewtopic.php?t=24427
    Austin
    1990 90 20v 1991 200 20v 1991 200 20v avant 1992 urS4
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    Quote Originally Posted by YODASFRO View Post
    Sounds like O2 sensor to me!!
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Veteran Member Three Rings BING's Avatar
    Sep 18 2006
    01' A4 2.8QM ,99' A8Q,93' //S4
    comin up fast on your left !
    Could be the 02 sensor ...did you check for a vacuum leak also?
    Get a can of MAF cleaner and spray out the ISV, and the MAF too, this can also be used on the 02 sensor to clean the carbon from on the inside of it....I had this issue when i was running rich......
    03' VW TDI in GTI clothing
    93' //S4 GT30/40R,VEMS,6MT(sold)
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    02.5' VW Passat Wagon 1.8t
    110 valves =;^)
    Austin Texas
    Quote Originally Posted by BING View Post
    True...check the BPV!
    Shawn
    Veteran Member Four Rings Silvant's Avatar
    Feb 12 2004
    Past: 95 Stg3 UrS6 Avant, 01 Stg3 A4 Avant
    LA | CA
    definitely have it checked first... you sound accurate for MAF, on the symptoms you described..
    if you do need one, i'm pretty sure the rs2 maf is available either through 2B or 034.
    good luck.
    Mr. Inappropriate Porno Avatar Man.
    " So do us all a HUGE FAVOR silvant...STOP breathing our air..and go kill yourself...you punk POS...."
