Results 1 to 28 of 28
    Mar 12 2008
    MD/DC
    CEL After Changing Oil WTF
    Changed the oil today, 3.0 Quattro. Put 4 quarts Pennzoil 10W30 regular oil (I know it was supposed to be 5W but its the winter so a lil extra thickness wouldn't hurt). got the oil filter from the dealer.
    Washed the car at the drive through wash. Driving around afterward, literally 10 miles and the CEL.
    Gonna get it scanned tomorrow at PepBoys / Autozone. Does anyone have any ideas as to what this could be? Heres the only things I can think of:
    *To thick of an oil - Should not throw a CEL
    *Not enough oil - Oil light shoulda came on not CEL
    *Water got into something from the wash - Shouldn't have happend since the hood was obviously closed. No direct water into the the grille either.
    B6 3.0
    Jun 08 2008
    Calgary AB Canada
    Re: CEL After Changing Oil WTF
    shouldnt you run thinner oil in the winter?
    Dec 25 2004
    Earth
    What year and mileage?
    Sep 23 2006
    Houston TX
    more oil. 3.0 takes almost 7 liters. not sure if that would cause a cel or not though.
    Mar 12 2008
    MD/DC
    2002. Just hit 46K. It is overdue for the 40K service which is a major service. Could be something that was supposed to be changed out during the service.
    I would think thinner oil would would give less protection during cold starts. Still shouldnt throw a CEL.
    B6 3.0
    Mar 12 2008
    MD/DC
    Just checked the oil. Stick is bone F'n dry like its running empty. How can you put 4 quarts in and the stick be dry?
    The block is still warm but its been sitting for about an hour.
    B6 3.0
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    3.0 uses aournd 6.8 quarts of oil if you change the filter. Not sure who told you it only takes 4 quarts....
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    ADD oil asap....our baby 4 cylinders take about 4, 3.0's are close to 7
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Mar 12 2008
    MD/DC
    Haven't started yet but added more oil, will let it sink to the tank and then check in about 15 min
    B6 3.0
    Established Member Two Rings thursdaysstrike's Avatar
    Sep 17 2008
    Orange County
    lol yah man i just changed my oil today on my 1.8t and it took 4quarts that would explain the dry stick on your 3.0
    ps
    add oil!
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    YEA ...it doesnt take 4 Qts....its not a 1.8t....the 3.0 takes....6.5 Qts....how i kno this i chnage my oil myself...every 4,500 Miles
    Mar 12 2008
    MD/DC
    Well after 6.5 quarts the light is still on but at least oil is showing up on the stick. I'll get it scanned tomorrow and let you know what the verdict is.
    Thanks for the quick responses.
    B6 3.0
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Quote Originally Posted by onceover View Post
    No, thicker oil in the winter and thinner in the summer.
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by 4Rings3Liters View Post
    thanks
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    I usually go with Mobil 1 0-30 in the winter and 5-30 in the spring
    Dec 19 2007
    York, PA
    if the proper fill level is achieved, the CEL should turn itself off after an x amount of miles is reached.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    unless theres sumthing wrong with ure oil sensor
    Dec 25 2004
    Earth
    Me thinks you got that backwards...
    The "heat" of summer, thins oil more, so, why would you want a thinner oil for summer?
    Today, with multi-viscosity oils(5w-40, etc...) you no longer have to switch oils between summer & winter. These modern oils can be run year-round!
    I ran Mobil 1 10W-30, year-round, in my 1993 Audi 90 V6 for over 13 years, without ever suffering a single oil related issue!
    Aug 26 2005
    This is not correct, it is backwards.
    In winter, a lower viscosity oil (thinner) is required so that the cold oil can flow to the parts as fast as possible, oil gets thicker when cold and takes longer to flow and establish oil pressure throughout the engine after startup.
    In Summer, a higher viscosity (thicker) oil is indicated because oil gets thinner as operation temps increase with the heat of summer weather. So a higher viscosity oil that maintains hot oil film thickness between parts is indicated.
    Mar 12 2008
    MD/DC
    So got the car scanned today at Autozone.
    P0431 - Warm up catalyst below threshold bank 2.
    Went to the dealer showed the code to a service tech and he said it was the cat. I though it would be the O2 sensor since it said "bank 2". The car is an 02 with 46K so the cat is covered under the EPA Federal Warranty, they'll replace it for free :)
    Still dont know why low oil would throw a CEL, but at least its a free fix. WHEW!!
    B6 3.0
    Jun 08 2008
    Calgary AB Canada
    So i was correct. gah!
    Buncha motorcycles
    Memphis, TN
    yes you should. most liquids get thicker in the cold.
    OP, dont assume the oil change and CEL are related. more than likely its just coincidence. its like if you changed your wiper blades then got a CEL. probably not related
    get the code read before you flip out
    APR Stage 2/AWE Intake
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Quote Originally Posted by Papachristou View Post
    If i changed my oil and got a CEL and then found out i put 3 less quarts of oil in and had been driving around... i'd be worried also.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Its a good thing you made that post though because 4 quarts is real low.
    Dec 25 2004
    Earth
    No
    Any of the Audi recommended 10w-30(V6), or 5w-40(1.8T) oils can be run year round!
    Todays multiviscosity oils can be run all year.
    Dec 08 2007
    Easton,PA
    didnt you notice that alot more oil came out then you put in lol?
    2002 A4 1.8t 5 speed maunal-revo stage 2
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by MikTip View Post
    No
    thats what audi recomends they also recomend u to pay 1500 for a timing belt job...they also recomend that it should be $125 per hour for labor to be done.....for me 0-30 in the winter and 5-30 in the summer works alot better then 10-30...and its actually 5-30 for the V6
    Aug 26 2005
    "Today, with multi-viscosity oils(5w-40, etc...) you no longer have to switch oils between summer & winter. These modern oils can be run year-round!
    I ran Mobil 1 10W-30, year-round, in my 1993 Audi 90 V6 for over 13 years, without ever suffering a single oil related issue!"- MikTip.
    Yeah, that is true. I run Castrol German Syntech 0w-30 all year here.
