Results 1 to 11 of 11
    Registered Member Two Rings 4BLKRNGS's Avatar
    Oct 22 2008
    Monrovia, MD
    metal engine sound
    ok i just spent the past 2 days searching all over for the answer to this and i cant find it anywhere well here is the problem:
    when i start the car or the engine speed is below about 2200 in either nutural or 1st gear. it doesnt happen all the time but it is a metal clanking sound coming from the engine block but i cant tell what it is. the car still boosts the same and i took off the front mount and looked at the intercooler hoses and they had no metal debris in them at all.i have no idea where to look next i took out the spark plugs too and there were not any metal on them either and the oil looked fine i had it changed 2000 miles ago.
    The subject is a 1998 Audi 2WD 1.8T AEB engine GIAC chipped with an n75 race valve and godspeed front mount intercooler. i ran the vag com already and have not gotten any engine codes at all so please dont tell me to go vag the car. any help would be greatly appreciated.
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    Re: metal engine sound
    Possibly the wastegate on your K03.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Oct 22 2008
    Monrovia, MD
    how would i check that. it doesnt make the sound all the tim usually its only after i drive it pretty hard.
    Oct 30 2007
    Griffin, GA
    You would have to take the downpipe off the back of the turbo, so you can get to it, and then maybe see if you can wiggle it and see if its loos.
    Maybe someone else that had a similar problem will chime in.
    ** 2001 A4 TQM
    Oct 22 2008
    Monrovia, MD
    bump.
    it stopped making the noise when i let it sit over night
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Oil pressure problems? No rattle in the AM due to the oil being colder and thicker maybe?
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Im having a brain freeze but i know what it is. Mine has the same deal and theres a lot odf threads posted on this. This first post pretty much sums it up tho. Lot of ppl never do ne thing about it and get by fine.
    http://www.audizine.com/forum/showth...sound+oil+idle
    Oct 22 2008
    Monrovia, MD
    alright thanks guys i think ill just wait a little while and see how it does on the next oil change cause im a little low on money right now
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    I'm going with the wastegate, happened on my car. Starting to make the same sound again now. Very annoying. No power when making that sound as well?
    Oct 22 2008
    Monrovia, MD
    o no the performance it still the same i still push 18 psi either way weather it is making noise or not
    Oct 19 2008
    South Africa
    Quote Originally Posted by 4BLKRNGS View Post
    Lifters...?
