Results 1 to 13 of 13
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Car misfires badly, What's my next step?
    The car is a 30V 2.8. Well a couple months back my car started missing real bad. Under heavy gas the car would almost die and the CEL would flash. If I kept it under about 20 it would run but very roughly. I replaced the spark plugs, the spark plug wires, and the Ignition Coil Pack. None of those fixed my problem so I got frustrated and brought it to the mechanic.
    He suggested the intake manifold gasket, Well he replaced that and the problem still is the same. I'm getting frustrated.
    BTW I forgot to mention the problem has mainly been cylinder 4 misfiring.
    UPDATE: The mechanic also tried swapping injectors, swapping spark plugs and plug wires, pressure tested the cylinders and all that. Nothing fixed the problem or moved the problem from cylinder 4 and the pressure tests came back perfect. He ordered a scanner from Audi that should be here in a few days so he can do more detective work.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: Car misfires badly, What's my next step?
    ICM .
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    Quote Originally Posted by generik777 View Post
    I replaced the spark plugs,the spark plug wires, and the Ignition Coil Pack.
    Do you mean the ICM (Ignition Control Module) or the coil pack(s), which there are 4 of and are an extremely common cause of misfires on the 1.8t?
    Check engine light?
    Have you scanned for codes?
    Which cylinders are misfiring?
    Mar 12 2006
    NoVa
    I fail... Didn't look to see you're a 2.8... Please disregard prior post
    May 12 2007
    MN
    Quote Originally Posted by MultiAudis View Post
    Check engine light?
    I'm talking about this. I have a 2.8
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    still have the old coil pack? since it wasn't the problem, you wanna sell it? Or i can trade you for a throttle body or MAF (haha im broke and desperate).
    May 12 2007
    MN
    OP Updated.
    May 12 2007
    MN
    Bump
    May 12 2007
    MN
    TTT
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    the first, and next, step should be to scan the codes.
    May 12 2007
    MN
    Quote Originally Posted by ghost6303 View Post
    Yeah, that's been done. Misfire cylinder 4 is what comes up.
    Nov 03 2008
    98A41.8TQM
    thats not a code. i want the number that came up, either P-xxxx or the vag code so i know exactly what it was. was that the only one single code in there? no other "too lean/too rich", 02 or MAF sensor codes? nothing?
    May 12 2007
    MN
    These were the codes that came up when I first scanned back when the problem started. The mechanic said that just the one for cylinder 4 is coming up now, The others might have been old or just fixed by the stuff that was done so far.
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16688 - Shareware Version. To Decode all DTCs
    P0304 - 35-00 - Please Register/Activate
    16684 - Shareware Version. To Decode all DTCs
    P0300 - 35-10 - Please Register/Activate - Intermittent
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-10 - - - Intermittent
