Originally Posted by
edge19lw
well i have to change the discs and this is the first time i'm doing this on the a4 and according to audiworld it says you have to remove the two 8mm hex screws on the back of the brake carrier
no you do not need to remove the lock carrier. All you have need is 13mm & 15mm wrench. After you removed the caliper out the way i believe there is HEX nut that is impact on to the rotor, so impact the HEX nut out & hit the rotor with hammer so it become loose. From there you should be able to slide the old one out & new one in.
That is really the right way to do it but if you want to do it quicker & have the same result the way i told you should be lock quicker
