Results 1 to 3 of 3
    Oct 29 2004
    02 S4 Avant 6spd Blk/Blk, 04 Mini Cooper
    Valley Forge
    Trunk Leak (yes I searched)
    So I have used the search feature on here, audiworld, and fourtitude.
    I have a leak in the passenger side of my trunk, it keeps filling up the rear well where the central locking system pump is located. I have cleaned the sunroof drain as well as running silicone around the rear tail-light. At this point I'm a bit frustrated as to where water could be coming in, and it's not just a drop or two, it's a lot of water, I've actually punched a hole in the rubber grommet in the bottom of the well in hopes some would drain out. I also have a towel in there that is constantly soaked with a ton of water. The water leaks even if the car is sitting.
    I've totally run out of ideas....does anyone have anything new?
    I'm going to find it and I'm going to destroy it. Possibly with dynamite.
    Sep 11 2007
    Dirty Jersey
    Re: Trunk Leak (yes I searched)
    my guess is a dis lodged sunroof drain
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    ^^X2. Its right by the vac pump so it would be my best guess. theres one on each side and it prolly got pulled out of the grommet. happened to me but on the opposite side
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
