Results 1 to 11 of 11
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Thumbs up Shocks/springs or coilovers under $750? srry if repost
    FIRST OFF. thanks for reading my long post and contributing your opinions.. I really just want to make sure i get my suspension just how i want it before i go and waste all the money i have been saving for this operation
    I have a 1997 audi a4 2.8 v6
    . I AM FINALLY RIGHT AROUND THE CORNER TO GETTING SUSPENSION!!
    I do NOT want to spend more then $750 on suspension, maybe more after alignment but no more then $750 for the parts.
    -I am mostly getting suspension for looks (cant hang with the 4x4 look no more)
    -less body roll and tighter, better handling
    -stiffness
    -want strong, stiff enough suspension so i can rely on driving 4 passengers and some extra weight around with no problems.
    -not going to track the car
    -dont want it super slammed and would like about a 2 finger gap. A little lower in the back obviously compared to the front.
    Current stock suspension measurements. prob blown shocks by now @ 123k and 11+ years old. ha
    Ground to middle of fender measurements
    -Front Driver side=27.25 inches
    -Front Pass side =27.50 inches
    -Rear Driver side =27.25 inches
    -Rear Pass side =27.25 inches
    Fender to tire gap measurements
    -Front =3.5 inch gap / 5-6 finger gap
    -Rear =3 inch gap / 4 finger gap
    after looking at the actual inches of the gap and what not, it seems sport springs would barley even make my car look low, maybe because my car just sits so high... so now im just really not sure if race will be to low or sport will be to high, i dont need it slammed pretty low i just want it to definitely look lower then a stock sport audi and maybe a stock sport beamer, even though beamers look pretty slammed with sport susp IMO.
    A few links to some suspension i was considering...
    http://cgi.ebay.com/ebaymotors/Parts...3A1|240%3A1318
    this one just popped up, and its looking good
    obviously with some shocks of whatever goes good with these springs.
    i would obviously buy 4 of them and get some nice springs to match.
    I ALWAYS THOUGHT THAT I WOULD BE GETTING BILLIES BUT THE MORE I READ I FIND OUT THAT THEY DONT GO WELL WITH QUITE I FEW SPRINGS AND CAN BE RATHER HARSH
    I would like to be able to have some give when i push down on my car to feel the "stiffness" but would like it to be stiffer then a sport susp audi which i pushed down on the other day(a friends sport 00 v6 a4) and it felt a good bit stiffer then a stock susp audi but would like it a little stiffer.
    OK GUYS WHAT SHOULD I DO!!!
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    Re: Shocks/springs or coilovers under $750? srry if repost
    im going with vogtland springs on my stock sport suspension shocks. they lower the car more then the H&R sports but less then the race springs. right where i want it
    Veteran Member Three Rings Robb12's Avatar
    Aug 04 2008
    Orange County
    Rocky, how much do the vogtlands run at? Also, it'd be sweet to see some pics!
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Here's some ideas..
    Bilstein/Vogtland Combo
    Vogtland Lowering Springs
    Then remember our Holiday Coupons as well!
    Holiday Coupons
    Established Member Two Rings ewuzh's Avatar
    Jan 02 2008
    CA
    Due to the low spring rates, these wouldn't be good if you are planning on going extremely low. And I'm definitely not saying I recommend these, but it seems you're on a budget and it isn't going to get any cheaper than this:
    $599 - additional 20% off coupon (on website) = ~$479 for full coilovers
    http://www.stratmosphere.com/vmaxx.htm
    But I can recommend the standard Vogtland coilover. My brother has them in his 01 A4 1.8TQM (^ bought them from PureMS actually). It handles great and it feels great. It's a little out of your price range, but they are worth it.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Dont waste your time or money on the Vmaxx coilovers. Unless you can find some used coilovers in your price range, just get a solid spring and shock combo.
    Id go with the Bilstein sport shocks and the H&R race springs. Some sites have package deals on them too.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings MJM Autohaus's Avatar
    Dec 20 2005
    Many VAG toys!
    T E X A S
    First and foremost, when doing suspension (especially coilovers and dampers), always ask "Do they come with a lifetime warranty?" If you're not getting a lifetime warranty on your suspension components, then why bother? $500 for coilovers? Are you sure you want to do that? Each and every one of these coilover manufacturers (you can use your imagination on whom I'm referring to) that offer these too-good-to-be-true priced coilovers are only offering one or two or three year warranties on them. Why?
    The same applies to shocks. If you're not using KONI or Bilstein dampers on your B5 then you're not using the best - both of which offer lifetime warranties on their dampers. $750 is within a budget to do a quality shock and spring kit with Bilstein, NEUSPEED, H&R, KONI, Eibach, etc. If you're looking do something with one of those lines, send us a PM for some personal consultation on what might work best for you, your driving habits, and for what you're trying to do with the car.
    : MJM Autohaus :: 210.DUB.PART (382.7278) :: AIM - mjmautohaus :
    Warehouse Distributors for APR | Sparco | MOMO | Eibach | StopTech
    .....and wholesale prices on OEM and maintenance parts for your Audi, too!
    Oct 01 2007
    1997 A4 2.8 QM
    thanks for the replys dudes, its really helping me out. I am NOT going with v maxx EVER!!! (step brothers haha)
    I am leaning on the vogtlands and billies, i do not want my car to be slammed on h&r race, its to low for me im almost positive, i want to be able to get to the snow and drive through it with no worries.
    Any pics of the vogtlands on a b5? 1.4 inch drop seems pretty nice, maybe not enough though im not sure...
    with what my car is measured at now... the average front being 27.5 inches from ground to the fender...
    27.5-1.4 inches =26.1 inches That is what my car SHOULD be at right...
    From looking at a previous post something with h&r sport springs, there ground to fender hieght was around 25 or 25.5 at MOST.
    So maybe those springs arent going to be low enough.. I really dont know.
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by kingtr View Post
    Here's a picture of a B5 with sport (but not race) springs on 16" wheels (not 5 spoke, but same height/stance etc. This is eibach w/ bilstein/konis 24.75" rear, 25" front.
    ^^^ This is right around the hieght i want it at.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Eibach Pro Kit: Springs and shox/strutz
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    Why is V-Maxx so bad?
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
