Results 1 to 10 of 10
    Senior Member Two Rings Joesturbo's Avatar
    Mar 28 2007
    Lewisville, NC
    Battery Install???
    So after 4 coil packs going bad... My car is telling me that the battery is dead - which might explain why the coil packs have blown because of the fluctuation in Voltage...
    So I have a replacement, but some magical Audi engineer decided that Allen bolts are best to secure the battery... Also there is a metal brace that is in the way which has to be removed. Anyone know the size of the allen bolt?
    thanks,
    Joe
    2010 A5, 2010 A3 SP, A4 Avant 1.8T 2004, Corrado G60 + 93 VR6, GTi 1.8T + VR6, 65mpg T-diesel Caddy, Jetta VR6
    Buncha motorcycles
    Memphis, TN
    Re: Battery Install???
    no but it shouldnt be too hard to figure out... i did mine in advance auto parts parking lot
    APR Stage 2/AWE Intake
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    No, but i DO know if you don't have an extension to reach the bolt, it's a major pain in the ass.
    -Matt
    FCDT Member #1
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    its easy.. just undo the two allen bolts on the passenger side part of that bar.... then put a large flathead screwdriver where the bolts came out and pry the bar out of the way a bit... then put an extension on your allen socket and you will be able to reach the bolt that secures the battery.
    I did my battery on sunday... took no time
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    its 7mm and what a pain in the ass
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    I was honestly going to do a writeup on this but thought it wouldnt be worth while... oh well.. next time
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    I used socket wrench with a 6mm allen head on it.... it's actually kind of a bitch...
    Everyone that jumps online is a pro "shits so easy" well when you don't have any tools or space to work in and it's 27 degrees out it aint easy...
    I could tell you I mold tubular carbon fiber race car frames in my basement, doesn't make it so.
    789whp
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    I just changed my battery and I'm pretty sure it's a 6mm allen/Hex.
    The easiest way I could describe, although a little more time consuming is to remove the 5 bolts (6mm allen) that holds your front strut tower brace in place(2 on each side and one in the middle). With it out of the way I used a socket w/ the hex bit attachment to get to the one bolt (bracket) that holds the battery in.
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    I did swap in a Optima red top.. which is much smaller and weighs less... I then put some double sided heavy duty velcro on the bottom then tightend the bracket down best I could...
    789whp
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by Howard Hughes View Post
    the battery can be removed in under 10 minutes.. i did it outside last sunday in michigan.. its not difficult. you only need to remove the two bolts on the strut tower brace on the passenger side, then you use a flat head to pry the strut tower bar towards the battery, which will give you enough room to get your 6mm hex socket (with an extension) onto the one hex bolt that supports the battery. a couple turns and that is out too.
    3 bolts cant take more than 5 minutes.
