Results 1 to 8 of 8
    Senior Member Two Rings Grk_A4's Avatar
    Sep 18 2007
    Philadelphia
    CEL and Engine Shuddering
    Hey everyone,
    I recently have been experiencing some problems with my A4. I am chipped with GIAC and about 2 days ago my cel came on. While I drive the car if I give the car too much gas the car begins shuddering as though it were not receiving enough fuel. I look at my boost gauge and this shudder begins when I am holding any amount of boost. If I take the car past zero on my boost gauge, i.e. holding any amount of pressure the shuddering begins and my cel starts flashing. I just changed my pcv valve and my diverter valve so I don't think they are the problem. Any help would be appreciated. Thank you!
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    Re: CEL and Engine Shuddering
    Check ur PCV valve open the hood and see if theres any oil on the cap or engine cover....that could be it i had the same syptoms
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    Sep 18 2007
    Philadelphia
    I just replaced the pcv valve. I thought that was the problem too. Thanks for the help though. Anyone else?
    Aug 22 2007
    2006 A4 QTM6
    forest hills queens, ny
    coil pack?
    Sep 18 2007
    Philadelphia
    I didn't know that coil packs went bad on the b7's. How would I go about checking a coil pack. Do I just remove the coil pack and inspect it?
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    99% sure it's a coil pack, same exact thing happened to me... twice Is it still under warrenty? Just bring it to the dealer and they'll check the CEL and replace your coil packs for free. Or if you're worried you can just buy some and pop them on yourself, it's easy.
    Senior Member Two Rings coolguy32's Avatar
    Aug 29 2008
    Rancho Cucamonga,California
    what year is your car??
    Aug 29 2008
    if it's 05, then it's prob the fuel pump........
