Results 1 to 16 of 16
    Nov 30 2008
    2015 Golf R
    Parkland FL
    About to drop car - want to make sure I don't rub
    On Friday I am putting Pro-Kit springs on my S-line Ti with stock 18" wheels and tires. I am also planning on putting 10mm front and 15mm rear spacers on. Chris at USP in Coral Springs says it will not rub and I trust his opinion as an Audi & VW tuner. I just wanted to know if anyone has tried this setup and find out if you had experienced any issues with rubbing or otherwise. I do have 4 people in the car at times if that makes a difference.
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Re: About to drop car - want to make sure I don't rub
    I'm still on stock suspension, so I don't know from experience, but I've read that a drop with 15mm rear spacers will rub occasionally. Expecially with weight in the car.
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    hey, im from south florida too, boca. are you installing the springs or usp? iv herd good and bad things about usp and chris, but my friends who have taken their cars there have all had good experiences.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    ti wheels anda prokit wont rub, the prokit isnt low enough to rub, if your in south florida you might want to check out wolfcars, they are one of the top dogs down here as far as vw and audi
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    i got 19x8 all around lowered on stasis ss and im rubbing on 15mm spacers more than merrier but its probably because im on 235/35s. the tires rub the fender itself rather than rubbing on the inside of the fender wall. the reason i got 15mm to make sure that the brake calipers clear the rims spokes. i just got 10mm forge spacers today and about to put them on. 15s should be fine if youre running the stock wheel/tire setup. post pics... hehe. good luck!
    ~~ engineered in germany... modified in brooklyn ~~
    Nov 30 2008
    2015 Golf R
    Parkland FL
    Thanks for the help. I know several people that have had work done at USP with good results. Don't know much about Wolf but I don't venture into Miami for much except the airport. Getting RS4 rear sway today and Pro-kit and spacers on Friday. Once APR exhaust gets installed on 12/15 I'll post pics.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    I rubbed with 15mm spacers and oem 18's, no passengers. I bought some 10mm for a steal and am happy. 12mm may work. FYI I am currently 25in ground-to-fender in the rear.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    Quote Originally Posted by blackbox619 View Post
    Your post is not helpful unless you state your offsets before spacers so he (or someone else) can use it to help calculate his own
    Just a tip.
    And you should be fine with 10mmF & 15mmR on stock Ti.
    Stance wont be super flush but it'll be good.
    Might rub with 5ppl. Worse to worse cut the front wheel tab, and cut the rear fender liner, maybe even some negative camber, gives you more clearance.
    I posted a thread about it, look it up under my history for more info
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Nov 30 2008
    2015 Golf R
    Parkland FL
    Quote Originally Posted by Elohite View Post
    Just a tip.
    Most of the time (but not all) the two people in the back will weigh 44 pounds and 75 pounds (4 year old and seven year old). so there is not much weight there.
    When you say it won't be super flush do you mean it will still be under the fender a little? If so, I don't mind. I don't think I would want it to stick out proud of the fender.
    Jan 14 2008
    San Antonio, TX
    No. It will be slighty tucker in under the fender, dont even worry about sticking out with those size of spacers
    Stock Ti wheels are 18x8 et 43
    With 10mm F and 15mm R you will be at
    Front: 18x8 et 33
    Rear: 18x8 et 28
    My car has Front: 19x8.5 et30 Front Rear: 19x8.5 et 20 235/35/19 Tires all around
    I cut rear fender liner, front tabs and have about -2.7 camber in the rear
    It doesnt rub (even with 5 ppl) and is pretty low (credit card clearance)
    (I am forgetting you tires, so what size were you thinking?)
    I just want more AZer's rolling around with good stances.
    Nov 30 2008
    2015 Golf R
    Parkland FL
    Front: 18x8 et 33
    Rear: 18x8 et 28
    I am going to leave the stock tires on for now and may replace with same size F1's or PS2's when they need it.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I dont think that will rub ( Not low enough ), but 10mm spacers make my rears rub bad.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Jan 14 2008
    San Antonio, TX
    Quote Originally Posted by Vinscap View Post
    No, what size are they? 225/40/18? I forgot stock specs
    Either way you're probably wanna gonna go with a 35 for a more low profile tire look
    Nov 30 2008
    2015 Golf R
    Parkland FL
    235/40/18 I think
    Nov 30 2008
    2015 Golf R
    Parkland FL
    Got the spacers and springs installed today. The prokit is the perfect drop for me. Does not rub and the spacers look great. I will post some pics when I get the APR exhaust and the OSIR mirrors installed in 10 days.
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    get your fenders pulled and rolled if ur worried, fixed any type of issues I had going to a 19x8.5 wheel
