Results 1 to 7 of 7
    Established Member Two Rings Pestilaence's Avatar
    Nov 21 2008
    2004 Audi A4, 2003 Yamaha R6
    Bloomington, IN
    Down-pipe for 3.0?
    Hey guys... did some searching and couldn't really come across anything that wasn't horrifically expensive. I was wondering if anyone knows of a down-pipe for the 3.0's that is kind of cheap, or an alternative that I should consider. I was thinking of just taking the car into a local exhaust shop and asking them how much they would charge for a straight-through with a hole for the O2 sensor. What do you guys think? I am looking for a very slight increase in performance, but mostly sound. I will be adding mufflers in the close future as well, but I don't know which ones yet.
    Apr 28 2005
    MD
    Re: Down-pipe for 3.0?
    cut out your cats and do piggie pipes or i can make you a set of pipes for $900, check my gallery for pics.
    Factory Ultra sport pkg , PES G3 S/C, Innovate Wideband,K&N, 3in Intake mid-pipe, Supersprint headers-downpipes-exhaust no cats, Snow performance, 2Bennett oil cooler, APR snub, RS4 m-mnts, SBclutch, Stasis cntr-diff-chng, 2Bennett coilovers, H-Sport sways, 2Bennett BBK, H&R spacers 8mm-10mm, BBS CH, Alpine, JL,USP Club Member#27
    Nov 21 2008
    Bloomington, IN
    Quote Originally Posted by 3.0 King View Post
    Might I ask what "piggy pipes" are? I'm guessing I'll just ask the shop to use the stock flanges, and make a straight pipe to take the place of the cat, correct? Is there much of an improvement by doing that, and what about sound difference?
    **Edit: BTW, do you have pics of your intake runner and or headers??? I saw the pic you have of it, and would like to see some more if possible.**
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Quote Originally Posted by Pestilaence View Post
    Unless your running a PES the power gains are going to be minimal. Not worth the money on a N/A car, unless your doing it for sound.
    High speed Ferrari movement...
    Nov 21 2008
    Bloomington, IN
    I just didn't know what they were. I had never heard anything called that before.
    Apr 28 2005
    MD
    yes, you smart. as far as sound, depends on what cat-back you have. IMO Milltek sounds the best. Gains are there. Try having a shop cut the pipe just below the cat and make a single pipe with new flange and bungs for O2 sensors and one bung for Wideband, spacers for your O2's would help to keep codes to a minimum.
    Sep 23 2006
    Houston TX
    Steve PM sent
