Results 1 to 18 of 18
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    snow tire questions
    I'm about to put my snow tires on my S4 and am wondering if i should put the ones with less tread up front or in the back? dont know how these AWD systems ware out tires.
    Also would you guys recommend a 225 or a 235 tire on our cars? I know factory is 235 but i've heard with snows its better to go narrow so you cut into the snow as opposed to "hydroplaning" over it.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: snow tire questions
    threadwear should be identical on both front and back, or it might ruin your transmission or quattro system.
    TEAM|AXION
    Veteran Member Three Rings ZEUSROTTY's Avatar
    Feb 19 2008
    Bolingbrook IL
    you want the better on the front... Reason is that you cant go anywhere without the ability to stear... Also for winter, you are right. The thinner the better.
    2010 S4 DSG Mods None yet...
    Gone 2004 S4 Mods: tinted 25%, APR Dowpipes, w/custom custom cat back including Magnaflow x-pipe Magnaflow bullet mufflers and Flowmaster D40's . Stock intake, APR Reflash - Hotchkins Sways - Koni Yellows front and rear - H&R Springs - Goodrich brake lines - Hawk+'s - Nitto NT05's for the street and 01's for the track. 18" R8 Reps... More to come!
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    Quote Originally Posted by speedydragon View Post
    you can be within 5% of teh final rolling diamater with quattro and still be fine...
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Stop scaring people, like the post above me as long as the rolling diameter is close you will be ok. The Quattro on the B6 and I believe early B7 S4's is 50/50 so it kind of won't matter where you put the tires.
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    How much less tread ? I ask because if the rears have very little tread then swapping ends when you least expect it will not be fun ...
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    hahahahaha....this is a little dramatic
    my car is 60% power to the rear and 40% to the front....if I wear out my rears faster, will my Quattro system fail too?
    please.
    Veteran Member Three Rings norsecarnut's Avatar
    Sep 15 2008
    2 Land Rovers, BMW E61 mt6
    I thought all the Quattros were 40:60, are some 50/50 all the time?
    - suppose mine will wear out even faster now that I have the 4:1 Stassis center diff? ;) joking...
    According to Stassis, compared to stock it grabs even more up front going into corners but then more rear bias coming out. Basically depends on how much you're on the throttle.
    Rotating tires will negate any of that though.
    2008 S4 Avant mt6 Dolphin - APR Full exhaust / Escort 9500ci-stealth install / backup camera / aux-in & ipod & cd / 35% ceramic / 2" hitch class 2 / Nokian WRG2 / HID fog / Stasis high-bias center diff
    AKA: jwest
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    Quote Originally Posted by jwest View Post
    iirc, sometime in the change from b6 to b7 it also changed from 60/40 and 50/50
    p.s. i really want the stasis diff
    1995 BMW M3 [sold]
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Put the best tread up front...stopping and turning are more important. Plus with the 04, I think you're 60/40 split. As for 225 vs 235, I'd go 235 to maintain your load rating. With 225, you'll increase rim damage risk and the difference in width is negligible.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Sep 15 2008
    Quote Originally Posted by XwalkerX View Post
    it's not too much really.
    AKA: jwest
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    On the 2005.5 B7, the split was still 50/50, as it was before that. The 2006s and above are all 40/60 though.
    Quote Originally Posted by S4J View Post
    Since hes 60/40 REAR/FRONT, it would seem you're arguing two different points. Yes turning/braking is possibly more important, so you might be better to put them in front. However, the 60% bias towards the rear would also mean you'd get more use out of having the better tires in the rear... Luckily for you, the 04 means you're 50/50 so don't concern yourself with that
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Nov 28 2007
    Massachusetts
    i can barely notice a difference in the tires... nothing to big at all... and 235 it is for the load ratings..
    I also want that center diff..
    Im a huge fan of Dunlop M3 snows... Any recommendations on other snow tire brands?
    Feb 01 2007
    I'm quite satisfied with my Pirelli Snowsports. Don't have much experience with other snowtires, however, but the snowsports have got very good ratings on tire rack, and they're working great for me.
    Sep 26 2006
    Nor Cal
    Quote Originally Posted by whartung View Post
    You miss understand...60 front/40 rear on the 04 B6. Went to 50/50 later, then 40/60 with the latest B7.
    Nov 28 2007
    Massachusetts
    im going to have to disagree with the first thing you said.... the 04 B6 is 50/50.... Audi would never install front bias differential in a front heavy already understeering beast
    Mar 26 2005
    Quote Originally Posted by sakimano View Post
    please.
    I'm not playing..I had to replace my tip tranny due to running a diff tire up front :|
    TEAM|AXION
    Sep 26 2006
    Nor Cal
    Quote Originally Posted by ginkof View Post
    Yeah I looked and looked and couldn't find where I read that so I stand corrected.
