    Junior Member Two Rings
    Aug 26 2008
    S.E. Michigan
    KO3 rebuild kit?
    i was wondering how much these kits go for and mainly where i can find them. i've been to plenty of websites and have had no luck? Also if anyone knows the going rate for these that would be appreciated also. "m trying to decided if i should buy K03's from somone i know for 500 that have been rebuilt already and are ready to install.
    Aug 06 2008
    Canadia
    Re: KO3 rebuild kit?
    $500 is a pretty good price provided someone who knows what they are doing did the work.
    ebay is $40 for a rebuild kit, online stores are $50, the stores come with more stuff.
    Its easy to rebuild yourself, mark off the oreintation of the hot and cold sides to the middle part, whatever its called, then score a mark on the cold side turbine and shaft so you can put it back together the right way for the balance, unbolt the shaft (its left hand threaded) and replace all the guts and use engine assembly lube so it does not go together dry
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    Yeah they're called K04's..... haha I kid I kid...
    789whp
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by MacDaddy View Post
    only $50? wow.. I was thinking it would have been more like $200 per turbo. Don't know why.. That's interesting to know it's really that cheap.
    Apr 18 2008
    Quote Originally Posted by Howard Hughes View Post
    agreed
