Results 1 to 3 of 3
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    Anyone running NGK PFR 7B's?
    Anyone using these in their S4's????? Are you chipped, stg3 or stock? Thanks,
    Aug 06 2008
    Canadia
    Re: Anyone running NGK PFR 7B's?
    i'm curious too, and how they run on a stock S4
    the B5 S4 is like the mafia... there is only one way out!
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    im stage 3 on 42 lb injectors and i run a 7 series plug from ngk.
    they are bkr's (iridium) but its the same heat range.
    when i installed them they were pre-gapped to .28. car ran fine until i hit 10psi. then instant misfires all over the place. took them out and closed the gap to .25 and they run like a champ.
    bkr6eix's are stock heat range so anything colder and you will need a smaller gap.
    next time around im going to try a bkr8 .. coooollld!
