Results 1 to 24 of 24
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Ebay universal O2 sensor
    I remember seeing a post a while back about universal bosch O2 sensors on ebay for like 25 bucks a pop. I've been searching for about 2 hours now and cant find that thread/post regardless of what i try searching for. Anyone have a link to it so i can order it. Thanks in advance and happy motoring
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Ebay universal O2 sensor
    Nov 09 2006
    Bronx, NY
    gladly, thanks for the help.
    2000 A4 1.8tq
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    how legit are these?
    2018 Mercedes GLC 300
    Dec 05 2007
    I bought both of my sensors from that guy. They do not come with connectors, but you can easily just splice them into the existing harness and wrap them with shrinking tube. The sensors are brand new units, and I do not know why they come with no connectors. I did not buy the universal ones though. When I purchased mine, his inventory was more surplus than it is in it's current state. He has the primary 02 sensor that I used still in his inventory, but he only has a universal one for the secondary sensor currently. I bought Bosch non-universal ones for the front and rear for ~$85 combined. Can't beat that price.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    The thing with these are, you have to solder them in, which could introduce extra resistance, which in turn can cause incorrect readings.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Why do you have to solder. Why not just cut the 4 wires twist them together and put a tube of shrink wrap over it. Sure its more work than a connector but it should work fine.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Dec 05 2007
    ^That is what I had done to mine. I did not install them myself, as I had my exhaust installed at the same time and told my mechainc to just install them at the same time. This is the techique he used and I have had no issues thus far. Had them on for maybe 8 months now.
    Los Angeles, CA
    man i paid $130 just for the front 2 weeks ago, u guys suck!
    Dec 14 2006
    Halifax, NS, Canada
    Quote Originally Posted by ILoveT View Post
    If they were that sensitive to resistance they would never work
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by Squarrl View Post
    I will murder you.
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    They send the ecu air fuel info as voltage readings, more resistance would reduce amperage not voltage. As long as you are not overheating the wire and making it brittle the connection should be as good as new and wouldn't affect amperes either. However I would only buy a factory part for something of this nature due to aftermarket part quality problems. I work with a guy with a weighted quarter it lands on heads 90% of the time if I was betting on it the damn thing would hit tales.
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    I've been looking for this but don't know what I'm looking for anyone know which one to get
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    You could like crimp them together.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    I'm wondering which O2 sensor I need
    Dec 05 2007
    You have CEL? What code(s)?
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    I can't remember them all but i needed the o2 sensor associated with B1S2
    t's a 00 2.8MQ
    Sep 17 2006
    07 cbr600
    Does anyone have the link to the auction for the primary O2. Link in this thread is dead. Thanks
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Quote Originally Posted by biketsai View Post
    solder and heatshrink is the next best thing to having the connector. crimping them is slightly worse then soldering, and twisting them together and electrical taping them is the most half ass way. actually no- wire nuts are the most half ass way.
    Nov 09 2006
    Bronx, NY
    i was taught that crimp connectors and shrink tubing are better than soldering and shrink tubing. reason being is because if the wire gets hot, it can remelt the solder and cause a loss of connection where as a crimp has a mechanical connection as well.
    2000 A4 1.8tq
    Nov 03 2008
    98A41.8TQM
    i suppose that could happen, though the standard 63/37 tin/lead solder thats used for electrical soldering melts around 375* F. that kind of heat would melt most plastic sheathing. i guess the best way would be to use those crimp connectors that are lined with solder so after you crimp the wire, you heat it up and it melts into the wires giving a nice connection, then heatshrink it.
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    Can someone repost the link to the ebay auction with the sensors please?
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
    Established Member Two Rings v3n0m's Avatar
    Sep 23 2010
    Kent, WA
    Quote Originally Posted by oneighty View Post
    X2
    Jun 04 2007
    Austin/DFW, TX
    You might just have to search for a universal 4 or 5 pin, whichever year model your car is.
    My 5-Speed Swap DIY
    - B6 USP
