Results 1 to 8 of 8
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    wtf? Dipped headlight?
    Ok so i got the "right dipped headlight" warning on my information center, and when i got that warning both of my headlights were fine. I got out of the car to make sure and yep, both headlights are in perfect working order.
    It wasn't raining when i got the warning, i didn't hit any huge pothole, i was going probably 10 mph in a parking lot about to pull into a parking space. I'm confused because i got the warning once, and it hasn't come back. It was on for about 5 seconds and then it went away. Just a faulty warning?
    - Justin -
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: wtf? Dipped headlight?
    Happens to me about once a week too. My passenger side headlight has a slight flicker to it too, I'm guessing it's on its way out sometime soon.
    -Darrick
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    I've gotten it before. Check the conenction to the back of the headlight; in my case the connection was a bit loose. Since then its been fine
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Jul 04 2008
    Seattle, Washington
    Hmmm, maybe mine will be going out soon. Oh well, if it does that gives me an excuse to get some new HID's all together. I think i have the stock ones now, so i'll probably upgrade to 6k or 8k. I want them to look more purple than blue though.
    But it's actually weird because this warning came on last week sometime and it hasn't come on since, i've also noticed no flickering of any kind. It's been kinda foggy out for the last couple days so it's pretty easy to tell. Although i did learn my headlights are in a cross pattern...
    - Justin -
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    i got it once. before i fixed the o-rings on my s4 headlights i had severe condensation I assume the moisture caused a short or some safety thing. it was fine once everything dried out and no problems since.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Jul 04 2008
    Seattle, Washington
    I haven't noticed any condensation in the headlight either. The only odd thing i've noticed is that today i was driving behind someone and my left headlight reflected pretty purple/bluish like normal and the reflection of the right headlight was almost the same color as my yellow foglights. But i'm thinking this is just a product of the lighting outside or something. But this is the only time i've ever seen the headlights completely different colors. They're usually the same.
    - Justin -
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by Capt. Obvious View Post
    same exact thing here.
    and the other night my left HID went out completely and wouldn't come back on. i had to drive 20 miles home with the high beams on as to not get pulled over. got flashed like 15 times haha!
    and when i pulled into my driveway, i turned the lighs off, and the lights flashed off then on again and the left light started to work again and has not given me trouble like that again...
    fucking vag electronic gremlins!!!
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    theres stuff like this
    that will help stop the flickering if you put a coat on the bulb connections before plugging them in
