Results 1 to 9 of 9
    Established Member Two Rings QuattroWerks's Avatar
    Oct 20 2008
    2008 Audi S5
    New England USA
    Review: STaSIS Rear Sway Bar
    Had this installed by my indie and it took just under an hour. Initial impressions:
    1. Wow that 28MM bar is beefy (and lighter than stock as it is tubular)!
    2. Car absolutely feels more neutral / understeer has clearly been reduced
    3. Absolutely improved levels of adhesion - there are a few corners that I had taken previously where the car would plow but now the car just simply stays planted; even at higher entry speeds
    4. I no longer need to back off the throttle in order to tuck the nose in - the car simply goes where pointed
    5. The car feels lighter on its feet now that it doesn't understeer so bad
    6. The combination of Quattro and the bigger rear bar now allows me to power through corners / power out of corners that I previously would have been concerned about the car running wide (similar to nos. 3 and 4 above).
    Overall: AWESOME upgrade and easily the best thing I've done to my S5 since the custom tune
    Definitely worth the $279!
    Part # for A5/S5: SA15.3100.00 (http://www.stasisengineering.com/)
    2008 Audi S5
    Custom-Tuned by FarnbacherLoles / AWE Downpipes / Milltek Exhaust / BMC Filter / European Headlights / H&R Coilovers/
    20MM/25MM Spacers / Blinder X-Treme Laser Jammer / STaSIS Rear Sway Bar / Xenon/HID Fog Light Conversion/
    Custom Subwoofer Enclosure w/Dynamat Everywhere / Lüsch Fog Light Grilles / JHM Short Shifter / Michelin Pilot Super Sports
    Jan 10 2007
    VA
    Re: Review: STaSIS Rear Sway Bar
    Next step: coilovers...for a serious handling improvement.
    Established Member Two Rings AJN334's Avatar
    Sep 21 2004
    Chicago
    sway bar is not listed on their website...
    Oct 20 2008
    2008 Audi S5
    New England USA
    Quote Originally Posted by AJN334 View Post
    Not yet AFAIK - suggest you e-mail Jim @ STaSIS ([email protected]) if you want to order.
    2008 Audi S5
    Registered Member Two Rings
    Nov 05 2006
    america
    does this also work for the A5, i suppose they will right? i had RS4 sways on my A4 before
    Nov 24 2007
    RS
    EU
    Do you have any picture?
    Thanks
    Oct 20 2008
    2008 Audi S5
    New England USA
    Quote Originally Posted by yamatoii View Post
    Quote Originally Posted by LittleDevil View Post
    http://www.audizine.com/forum/showthread.php?p=3010826
    2008 Audi S5
    Sep 18 2008
    Sonoma, CA
    Thumbs up Re: Review: STaSIS Rear Sway Bar
    Sorry for any confusion ladies and gents. You may find the rear sway bar at the listing below. Just in time for the holidays!
    http://www.stasisengineering.com/Cat...D.aspx?PID=211
    Registered User Four Rings OEMplus.com's Avatar
    Feb 27 2004
    2x VW, 2x Audi
    OC, CA
    I can second the recommendation for this bar. We installed one last week on an S5 and it's great!
    We have some before/after photos around here somewhere...
