    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    smoke coming from oil cap...?
    I started my car up yesterday morning and let it idle for about 10 minutes. After pulling it out of the garage I saw a small amount of smoke coming from my drivers side wheel well. I popped the hood and it looked like it was coming from the oil cap. there wasnt alot of smoke so i had a hard time telling where it was coming from. Also it smelled like burnt rubber. Has anyone ever expierenced anything like this? Also has anyone smelled their dip stick recentley? Mine smells like gas. is that normal?
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: smoke coming from oil cap...?
    You sure your coolant tank isn't leaking?
    May 31 2008
    New York
    coolant reservoir tank is not leaking but i have been smelling coolant for the past 3 weeks but my levels are staying good in the tank
    Sep 19 2008
    Toronto, Canada
    Are you getting any leaking on the floor underneath your car?
    leaking fluids + hot engine = smoke.
    May 31 2008
    New York
    Nope nothing on the floor. I always check to see if there is anything on the floor. FYI i do have a bad aux water pump thats needs to be replaced
