Results 1 to 40 of 50
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    big turbo question
    i am looking to go big turbo in a few months. already started saving n stuff. whats the safest and best way to go?
    Buncha motorcycles
    Memphis, TN
    Re: big turbo question
    OMG, go eat a pistol!
    what mods do you have now?
    you will need the following before even considering a BT:
    FMIC
    clutch
    exhaust
    brakes/suspension are optional but needed with the upgraded power
    and all the little shit like TIP, shifter, test pipe/hfc, boost gauge, coilpacks, fresh TB if you are getting up in mileage
    APR Stage 2/AWE Intake
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    i got stage1+ unitronic, full 2.5 inch turbo back exhaust, intake, forge bov/dv, boost gauge
    Buncha motorcycles
    Memphis, TN
    so you need a clutch and FMIC before you even consider a BT then...
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    You can wait on the clutch until it goes. Depending on how you drive and if you are original owner, you can get by with stock cltuch for a little bit. I'm at about 10k on stock clutch still. But I'm original owner, always rev match, and rarely balls-to-the-wall launch. That will all change after this winter.
    My 2004.5 APR Stage 3+ is SOLD
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by rxrep View Post
    you are a serious exception to the rule!
    did u decide on a clutch yet?
    Jun 08 2007
    Orlando, Fl
    A clutch is not a necessity but you will not be capable of squeezing all the performance out of your setup without one. I am at 3500 miles on my GTRS and still using the stock clutch. I'm only at 65k and I don't launch so I will replace it when it decides to go. To answer your question you should go with an eliminator setup, a lot of bang for your buck and relatively straight forward install should you decide to do it yourself. Check out Eurocodes Ultimate solution and do your research.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    ima wait till mine starts to go. but when it does southbend. um for the 1.8T GTRS Eliminator Hardware Kit... what components should i get with it? injectors and that kind of stuff....
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Quote Originally Posted by Greek Yayo View Post
    550cc injectors with harness
    ATP manifold
    neuspeed tip with GTRS option from eurocode
    Forge 007p DV
    Evolution Ravewerks Competition FMIC
    Coilover suspension with rear sway bar
    Upgraded rotors, calipers, pads, and brake lines
    ...not to mention the software tuning to go with your turbo
    All of these upgrades are mandatory to do a properly safe BT upgrade.
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    i need 550 for the gtrs elim kit?
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    I think a bunch of people use 440s with it and have no trouble, but there's been multiple 550 vs 440 discussions. Pretty much just get the 550s.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    get the 550cc's.
    Mar 20 2006
    Widgget, whats up with your car? Make any progress?
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    ok 550 it is. i been serching aroun and havenbt seen any for my a4. Another thing i have the forge splitter bov/dv is that good or i need the 007?
    Mar 09 2008
    is full of crap.
    Boston, MA
    Your splitter should be fine. www.eurocodetuning.com for a pretty much complete GTRS setup with injectors included.
    -Nick
    Mar 20 2006
    You don't NEED to get a 007p, almost any aftermarket DV will do. I personally would shy away from a BOV. Our cars are meant for DV's so why change it to a BOV?
    May 24 2007
    Southern California
    someone seriously needs to make a sticky on what is needed for a bigger turbo, specifically aimed towards the GTRS.
    Kyle
    2.0L Revo GTRS Eliminator
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by A4natomical View Post
    I did, some people read it but its old news now
    - Clint
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    cmon. My thread had all this info
    Oct 22 2005
    Reppin the Mitten.
    Theres a lot of GTRS build threads. And lots of turbo information available.
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    get the 550 or 640 becuase if you plan on runnning more than 23psi the 550 will be running in the 90% range of there duty cycle which could spell disaster for you and your motor and they are all within 100 dollars of each other so dont be cheap. that is the best advice i can give you.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    I've had my BT setup for almost two years now. Got 20K miles on the BT clock. STILL ON the ORIGINAL FACTORY 1st Virgin Hydraulic CLUTCH.
    Quote Originally Posted by Papachristou View Post
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jun 11 2005
    FOR THIS VERY REASON, and THIS REASON ALONE!!!!!
    Quote Originally Posted by KPC1.8TQuat View Post
    2003 1.8T
    Feb 17 2005
    Sarasota, FL
    Plenty of BOV and Splitter valves that run perfectly fine on our cars. Its your choice, the car will not run better or worse with either ...
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    ok my friend with an srt4 said that i also need an exhaust manifold is this true? if so what do yous recomend?
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    wow im retearted never mind lol
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    ok the gtrs elim kit. what size turbo is that cause one wenbsite said gt28 and the other said 25...
    Jun 11 2005
    2003 1.8T
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    yea but i want to save money and stay with unitronic. the bt unitronic is for the gt28 and 30. is this either of them?
    Jun 11 2005
    No Clue. Gotta ask your UNI buddies.
    2003 1.8T
    Jun 30 2007
    Raleigh, NC
    the GTRS kit will do you fine - since you've already got unitronic i vote that you go ahead and get 630cc injectors.
    get some IE rods if you want to run high boost daily and you're going to beat the shit out of your car.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    im going to beat the shit out of my car?? meaning what? im going to do everything right and not half assed. i wont launch my shit. lol idk i say this now maybe wen it done i see aha
    Jun 11 2005
    I think it was a compliment.
    But yeah, with the proper tuning and hardware, go ahead and drive the hell out of your car (beat the shit out of it)/Have a good time / ride like the wind/ go like stink / hail the harbinger / pedal to the metal / loose cannon / floor that sucker ...
    i'm out of synonymous idiomatic phrases...
    2003 1.8T
    Jun 30 2007
    Raleigh, NC
    meaning drive it hard. (like i do mine) wan't implying anything about the install - just afterwards. if you're going to drive it hard on high boost you might pop a rod... just fair warning. plently of people run that kit and have no issues.
    but i was the first person to run it with a unitronic 630 file and i did have issues. so i'm giving you the benefit of my experience NOW when it could save you a few thousand bucks. a set of rods is cheap to buy, cheap to install, and cheap insurance when you think about it... then you're free to crank it past 24psi if you please and beat the piss out of it day in and day out. (mine lasted about 2 weeks under those conditions with the stock rod... search my created threads for pictures of what happened)
    The Awesome™
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    oh lol. and yea im just tryin to research as much as i can before i buy anything, like im clueless to this project i got my boys and you guys givin me advice and im jus going crazy lol. quick question wats the diff between jus the turbo kit and the turbo elim kit?
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    listen to B6lovin . . . i also decided i am going with a gt71r in the spring/early summer.. im just working on getting my car cosmeticlly how i want it now and get EVERY supporting mod i want before i upgrade from my k04... so after my front bumper is shaved/carbon fiber boser is painted nd clear bra and then faces on my wheels painted... im doing labonte motorsports water/meth kit and EBC..this way when i get the gt71r all i hafta do is get the turbo,injectors,rods(might do pistons also), and i will be getting dyno tuned... i rather have the peace of mind that i can beat the car and not worry bout throwing rod
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Oct 29 2005
    10speed
    San Francisco, CA
    OMFG.... Get Revo
    http://www.audizine.com/forum/showthread.php?t=96446
    /thread...
    - Clint
    Jun 30 2007
    Raleigh, NC
    the eliminator turbos are designed to bolt up in the stock location, on the stock manifold, and retain as much of the stock setup as possible.... obviously that's not good for making power - but theoretically you could unbolt your ko3 and bolt one of those on and be good to go.
    the kits come with a new higher flowing manifold, a new TIP, you can get an inlet adapter to make it 3" instead of the stock size flange that comes on the GTRS, they come with lines and install hardware also.
    personally for you i'd recommend the "GTRS hardware kit only". if you want you can then order a velocity adapter and neuspeed TIP - but if you go with unitronic you could just get the velocity adapter and get a MAFless tune - and then you either make an intake like normal, or you just stick a filter on the end of your turbo and call it a day. oh, you'll also need the manifold... look for one used in the classifieds
    The Awesome™
    Jun 30 2007
    Raleigh, NC
    i cant believe you said that clint
    The Awesome™
    Mar 20 2006
    Quote Originally Posted by B6Lovin View Post
    Hypothetically, if I were to run a GT71r elim with Revo tune on my car, at what PSI would I start to think about getting rods?
    I'm a TIP so I wasn't planning on pushing past 22 PSI or so.
