Results 1 to 7 of 7
Thread: Control Arms
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Control Arms
    Has anyone gone through their control arms in 35k? I think my pass side is shot. I could bring it to the dealer but they might tell me the suspension i put on cause the quick wear.
    The usual things!!
    Resistor Install
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Re: Control Arms
    Wait, control arms?
    How do you wear those out? Do you mean the bushings?
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Feb 16 2008
    Oakdale, MN
    Re: Control Arms
    On another site I posted that my car was making a clunk sound when I drive. they told me my control arms are probably bad.
    The usual things!!
    Resistor Install
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Re: Control Arms
    My car has 38k mi and is making a chatter sound on the front left corner. Sounds like metal-to-metal contact when I drive over uneven pavement...like a blown shock noise (it's not). I don't hear it when I drive over rough roads, bumps or potholes but it's very evident over mildly undulated roads. I think it's the ball joint or the front sway bar bushings because both seem to have slight play but I have to take it in again. Last time I was at the dealer, they couldn't detect the sound (the roads near the dealership are too new ) and for some reason they changed the wheel bearing which didn't fix the problem.
    When are you taking it in to get the control arm changed? Does your problem sound similar to mine? I'd be interested to hear the outcome of the control arm fix...the rattle is driving me nuts!
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Feb 16 2008
    Oakdale, MN
    Re: Control Arms
    Yeah!!! It sounds like a blown shock and that is what I thought was wrong first but my bilsteins only have 16k on them and would hope its not blown. Mine is in the front right. I have to go to work now but I'm going to try and call audi and tell them whats up and see what I can do!
    The usual things!!
    Resistor Install
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Re: Control Arms
    I'd probably have someone confirm that before spending money on replacement control arms. An internet diagnosis isn't generally all that reliable. If you don't want to take it to the dealer, take it to a local shop and have them take a look.
    Dec 26 2007
    PNWR
    Re: Control Arms
    Why would he be paying for the repair? This is a warranty fix.
