Results 1 to 8 of 8
    Jun 20 2008
    Vancouver
    HELP!! engine oil problem
    when i was driving home tonight at 815 i had my engine oil low light came on.... and because all the dealerships are closed... i had to go to the gas station and got some Pennzoil SAE 5W30 oil to top it... i want to know if that is ok... coz i know that audi uses castrol and i dont know if that's sythetic or no...
    and i am planning to go to my AoR tmr morning see if they can have an oil changed for me... do u guys thing they will do this for free?? i am covered with the audi care.. or should i get some castrol and change it on my own? TIA
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: HELP!! engine oil problem
    Motul 5w40 or bust.
    but you'll be fine.
    CT4952
    Jun 20 2008
    Vancouver
    does anybody know if the dealership charges you for any non-scheduled oil change??
    if u are covered with audi care
    Veteran Member Three Rings Clown4's Avatar
    Aug 29 2008
    '08 Quartz Gray S-Line B7 2.0T
    Rainbows and Unicorns
    probably they will for the oil.
    Well... I went in for a non-scheduled checkup @ OpenRoadAudi,
    they hoisted it, test drove it, washed it, vacuumed it... light detailed it...
    washed my floor matts... wiped all of my interior...
    charged me with big $0.00
    I'm not sure about the oil change though...imma get a bottle in my car just in case...
    2008 B7 A4 Quartz Gray 2.0T Quattro 6-spd MT.
    Full S-Line | Special Edition | Technology Package | HomeLink
    ____The Last of B7._
    Jun 20 2008
    Vancouver
    ya u should... i had my first engine oil light on with around 6000 km on my 08 b7
    Registered Member Two Rings s2000_s4_525's Avatar
    Apr 25 2007
    B5 S4 stage 3+++/ Turbo s2000
    Canada, British Columbia
    Quote Originally Posted by Siggiepop View Post
    Motul 5w40 or bust.
    but you'll be fine.
    Agreed
    Stage 3 s4 Wicked Motorsports... / S2000 turbo/ Soon to expand....
    Dec 14 2008
    2002, B6 A4 1.8T 5 spd
    I've had my low oil light come on just for cornering to fast, long road trips will set the light if the oil becomes to warm, I was using castrol for the longest time, I now use a european oil called ELF, It's all what you prefer, Elf seems to hold up against the heat a little better than the castrol did, I have been using elf now for about a yr and have not seen the low oil light since. Premium oil conditioners work well against the heat and the frigid cold, helps your engine against the dreaded molecular viscosity issues!!!
    Dec 01 2007
    Markham, Ontario
    if you have audi care, can you bring ur own oil for the scheduled maintances ?
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
