Results 1 to 2 of 2
    Veteran Member Three Rings Monkey77's Avatar
    Oct 30 2007
    2005 Audi A4, Tiptronic.
    new jersey
    Question HIDs causing fault codes????
    Hey guys, recently installed a Phillips ballast HID kit. Within one day of installation I was throwing up warning light left and right. Did a diag on the car, and it read that my ECS control module might be faulty. Since the codes only come on randomly when I turn the lights on, I'm not sure if I have a short somewhere and its giving me a false code or what. Anything help? Thanks in advance.
    " You can't be lucky all the time, but you can be smart everyday."
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    Re: HIDs causing fault codes????
    I had a similar issues, but it was causing my ABS light, Brake light, and ESP light to come on. It ended up being a bad ballast on the drivers side, it was causing a big voltage spike which in turn made my ABS not work when I turned the lights on. I replaced the ballast, and it all went away. I also cleaned up the ground on the firewall with a wire wheel and threw away the plastic pieice under it, whatever that does. Good luck.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
