Results 1 to 13 of 13
    Senior Member Two Rings audiholix's Avatar
    Jul 18 2007
    335xi coupe / 8p a3 / b5 a4
    opinions on rieger v2 sides w/ s4 front & rears?
    Guys,
    I've had a pair of v2 sides sitting outside my balcony for over a year now and I can no longer stand looking at my ugly black stock a4 sides. I've got s4 fronts and rears but I'm concerned that the v2 sides will sit way lower and not match with the s4 fronts & rears. I wanted to try something different than s4 sides but don't want to waste time painting these things if they will look straight up weird. Appreciate some feedback, suggestions or input as well as pics if anybody has seen this combo before.
    08 a3 2.0t
    10 a4 quattro
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: opinions on rieger v2 sides w/ s4 front & rears?
    IMO, the V2 sides are kinda too aggressive to fit the s4 "look". S4 skirts are nice and subtle.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    2nd. the side skirts will be lower than the front and rear and will look goofy. you could do a lip under the front and a valence on the back but then you're looking at more $ for parts and painting
    '17 Ibis White B9 A4 quattro P+ S-Line
    Sep 01 2004
    hawaii
    i had v1's with your setup before and it didn't looke too bad...
    Current:
    2002 Honda S2000
    2002 A4 1.8T
    2001 A4 1.8TQM
    2000 A4 1.8TM
    Connecticut
    This is Rieger V1 sides with S4 rear and RS4 front... not sure if it'll help in your decision. The V2's are much deeper, so it's probably gonna look awkward with the S4 front and S4 rear. Just my opinion.
    01 a4 1.8tqm, giac x, borla, h&r sport
    7.66 CAPS
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Personally, I'll go with the OEM S4 sides.
    Especially if the V2's are deeper than the V1's pictured above.
    Mar 01 2007
    WK2
    Quote Originally Posted by kjgarreau View Post
    technically that's a reiger front, not oem RS4. the reiger hangs lower than oem bumpers (S4 and RS4) so if he has an oem S4 bumper the side skirts will still be lower
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    Does the S4 bumper just plug and play on the B5 A4 or does it need some mods to fit?
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    ill trade you my v2 sides for s4 sides
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    Quote Originally Posted by kampfer View Post
    direct fit. i just did it
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    May 18 2008
    SOOOOOO Cal
    Cool...
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by goody6691 View Post
    what? who are you even talking to and how does that make any sense in this thread?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Feb 23 2005
    calm yourself, i miss read the op. i thought he had s4 sides. sorry
    Dave
