Results 1 to 30 of 30
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Question Stock S4 Exhaust Valving?
    I was wondering if anyone knew if there is any sort of valve on the stock B7 S4 exhaust.
    It seems to me that at around 3000 rpm the exhaust sound richens up a lot, more so than a consistent exhaust system which is standard all through the rev range would.
    It could be in my head though. Anyone know for certain?
    [ps. I searched and read a thread which discussed how the B6 exhaust before 2004 was actually reduced in sound by the mufflers above 1700 rpm, but I think that is something different entirely]
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    Re: Stock S4 Exhaust Valving?
    don't quote me on this, I think there is a vacuum solenoid on each muffler that opens up an additional exhaust passage before the tip around 3000rpm. your higher vacuum between idle to 3000rpm holds the valve shut, than as rpm increases, the valve opens up. Its not in your head, the volume should increase at 3000 rpm. I'm trying to figure out if I was to add a vacuum limiter inline before each solenoid, if the valve will open at a lower rpm. anybody feel free to chime in with opinions. I know the reasoning is to build low end torque.
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    yes there is a vacume line...i unplugged mine and it sounds nice for 2 minutes of work........i believe it is for "drone" affect so you dont get drowned with that los sound.....if i remember correctly
    Dec 06 2006
    DIY to unplug? And easy to undo (replug)?
    Nov 16 2008
    Hudson, WI
    if you roll under your rear bumper and look behind the exhaust tips, the vacuum lines are easy to see. just pull them off, and FIND SOMETHING TO PLUG THEM WITH. a small bolt would work. But if you don't plug them, you will have a vacuum leak. Easy DIY.
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    you will see the valve. Just look at the mufflers from behind the car. The valve open and closes to keep the exhaust tone in check down low. Once you see it the whole thing is kinda cut and dry easy. But if you still have questions post them up.
    IMHO leave the valve in until you replace the exhaust. Its not like it is robing the car of any REAL power.
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Oct 11 2008
    So basically unplugging that vac lines will make the sound louder without doing any damage to the exhaust system? If so, sounds good. lol
    Jul 24 2008
    chicago
    Quote Originally Posted by Samster View Post
    Yes just make sure to tend to the Vac lines
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    any before and after sound clips?
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Dec 06 2006
    I'd love to hear an open valved video if anyone does it
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    Can someone please post a pic of the valve. I know the RS4 has an exhaust valve but I don't think the B7 S4 has one. I looked on my car and could not find any kind of valve under there.
    Senior Member Two Rings EnjoyIncs's Avatar
    Oct 24 2006
    '04 S4 DG
    Worc MA
    here is the valve on a B6
    http://cgi.ebay.com/ebaymotors/AUDI-...Q5fAccessories
    I know the bmw 335 has a valve and it makes a huge diff in the sound when it is always open. Normally it would only open at full throttle. All you have to do is put a small hose clamp on the vacuum line and it will stay open all the time.
    Senior Member Two Rings hayasa's Avatar
    Aug 25 2008
    Just replaced my cat-back on my B7 S4. No valve at all (external) unless something else is going on in the muffler that I can't see. (BTW, I installed the Corsa exhaust one of the members here was selling. Sounds *mean*.)
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Quote Originally Posted by EnjoyIncs View Post
    Post a bigger version of the bottom pic please.
    Aug 30 2007
    Az.
    The B7 exhaust is different. I looked at the Ebay pics and saw the valve.
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by J.the W. View Post
    +1 No valves on the B7
    Oct 24 2006
    '04 S4 DG
    Worc MA
    Quote Originally Posted by ...Mark... View Post
    That pic is of a VW. I was just using it as an example. And I don't have a bigger one.
    Oct 03 2008
    Atlanta BITCHES!!!
    I was being lazy.. I went outside and saw what you are taking about.. Looks like i'm stopping by H.D. tonight on my way home to get something to clamp those up.
    Oct 24 2006
    '04 S4 DG
    Worc MA
    I hope it wont throw a CEL. Also the bmw guys say it takes longer for their cars to warm up due to less back pressure when the valves are open.
    Dec 06 2006
    The golf tee mod you are talking about (for hte 335i) is not exactly what you say (unless you're speaking of something else). The golftee mod as they call it makes the exhaust come out both piipes all the time, whereas usually it only comes out hte left on the 335i until about 3000 rpm or something
    Oct 24 2006
    '04 S4 DG
    Worc MA
    Quote Originally Posted by Cargo8 View Post
    Could you please explain? I thought the way it worked on the B6 was very similar.
    Valves are closed until a certain rpm / blocking the vacuum line lets them stay open all the time.
    Mar 17 2007
    new york
    i dont know specifics but they give more raspy sound when under hard throttle...it will not throw a CEL because one of my plugs fell off for like a month and nothing happend so it will not do anything to the car....this is very common in the R32's
    Oct 24 2006
    '04 S4 DG
    Worc MA
    Did you stop at the store? Could you do a before and after sound/video clip?
    Oct 03 2008
    Atlanta BITCHES!!!
    I did, and no i can't because i don't have a video cam. Sorry..
    Like others said, its noticable under throttle, but to be honest if i didn't know what it sounded like before i may have thought it was stock especially at idle. Its just a little more audible, kinda like the 350Z/G35 cars when they are under a load but w/ a V8 grunt to it rather than the Nissan raspy sound. Its louder than stock but not by much.
    Try it out, its a free mod, and if you don't like it its easy enought to switch back.. It takes 15 minutes.
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    If this is like the R32 you will lose a load of low end torque. It's not just a noise thing.
    Suck it and see.
    Oct 24 2006
    '04 S4 DG
    Worc MA
    What type of clamp did you use?
    Oct 03 2008
    Atlanta BITCHES!!!
    I had a wooden dowel laying aroung the garage. I just cut it to the length that i needed which was about an inch long, grabbed the hose w/ one set up pliers and pushed the cut piece of the dowel in with another. I took a blade to one end of the dowel to make a little of a point w/ it so that it was easier going in.
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    what a funny thread
    Senior Member Two Rings momoney's Avatar
    Sep 20 2007
    Bellevue Wa
    Quote Originally Posted by MOFSTEEL View Post
    +2 I dont have a valve on my exhaust unless i am not looking at the right spot
    Senior Member Three Rings BsixSfour's Avatar
    Feb 06 2008
    B6 S4
    SoFL
    Quote Originally Posted by momoney View Post
    Either I'm blind, or the B6's don't have it either
