Results 1 to 11 of 11
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    Help: Ziza city lights --- i suck at life
    So i read this one thread that discussed dropping the Ziza led bulb into the headlight housing... which of course I ended up doing....
    I tried a magnet and that did not work. How do you get this thing out? the bulb actually came off of the wire harness when i slipped it into place and just fell right in. I was messing with it because i couldnt get either of them to work, thus i must have loosened the bulb.
    Tips?
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Help: Ziza city lights --- i suck at life
    Make a long straw thing or use a bent coat hanger with either double sided tape or gum or something on the end to poke in there and try to get it out... I have small hands so just made due with my god given abilities.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Use a bendy straw with single sided tape wrapped in a circle and attach the circle to the end of the straw. Bang the headlight to get the bulb where you want it, and when you pull the bulb out make sure its going in the same direction as your straw so it can fit through your high beam hole more easily.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    open up the headlight and use it as an excuse to do the cc mod. 2 in 1 right there
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    ^^that or get one of those things that are like a metal straw with the little claw at the end and pull it out.
    Sep 18 2008
    Pittsburgh, PA
    But i dont know where it rolled too. Can it get lost in the headlight?!?
    Jul 16 2008
    San Francisco
    No, just bang on the lense and you should see your little friend again =)
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    Happened to me
    I had to remove the bumper to remove the headlight, then it was cake from here.
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Elohite View Post
    Happened to me
    ^do it
    Sep 18 2008
    Pittsburgh, PA
    I know how to remove my bumper, but no clue how to remove my headlight.
    Veteran Member Three Rings Tru NY Player's Avatar
    Apr 27 2007
    TIME MACHINE
    Tha M.I.A.
    ^thats weird..you know how to remove the bumper but you cant take your headlight off? lmao..
    lift your car up and shake it out.. lol
    'Leave sooner, drive slower, live longer.'
