Results 1 to 22 of 22
Thread: stage 2 or rs4
    Registered Member Two Rings chris marchant's Avatar
    Dec 01 2008
    2001 Audi s4 1998 audi a4 1997 jeep wrangler
    Alexandria, VA
    Question stage 2 or rs4
    hey guys, i have a 2001 s4 b5 and i have it chipped and many other mods, i have yet to replace my clutch and with the extra horsepower added my clutch can no longer handle it and is beginning to slip. so my question to you is should i install a rs4 clutch or should i find a stage 2 or 3 clutch?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: stage 2 or rs4
    your clutch is just worn. an s4 clutch can handle stage 2 + power all day.
    rs4 clutch is a great solution for upgrade thats not too costly
    Dec 01 2008
    Alexandria, VA
    Re: stage 2 or rs4
    thats what i thought it was, just wanted other opinions before i started blowing away my paychecks. thanks
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: stage 2 or rs4
    Here's a good question before you go shopping.
    What are your futur power plans for the car? Stage 3?
    If so, my opinion would to do the clutch once, not twice. Ya dig?
    Jun 01 2008
    Apopka, FL
    Re: stage 2 or rs4
    an RS4 clutch is a good replacement.. but a clutch is one of those things I would want to replace with a unit that would exceed my needs, just incase i want to do something later, and also because the amount of work and cost involved. If you use components that will be working at their maximum all the time, you'll be replacing them very quickly.
    Dec 01 2008
    Alexandria, VA
    Re: stage 2 or rs4
    i plan on eventually having about 550-600 hp
    would the rs4 clutch handle that?
    Jul 26 2008
    Jersey
    Re: stage 2 or rs4
    If you are not going to go stage 3, then the RS4 clutch is fine.
    If you are going stage 3, then go with a stage 3 or 4 clutch.
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    Re: stage 2 or rs4
    550-600 HP would not be a good day for that rs4 clutch
    i had the same issue as you and i ended up buying a VAST stage 3 with lightweight flywheel so that i would never have to do it again since i will go stage 3
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Dec 01 2008
    Alexandria, VA
    Re: stage 2 or rs4
    how much did that run you?
    Jan 19 2007
    01.5 S4 AVANT 6spd
    S. OC & PC UT
    Re: stage 2 or rs4
    I was in this same predicament a couple weeks ago, and decided to go with the RS4 setup wit a single mass flywheel b/c the stage 3 and 4 options were outta my price range. plus its gonna take me another 5 yrs to save up for the stg 3 kit anyway... HAHA I should be picking the car up today so I'll let you know as soon as its broken in how it feels
    Dec 01 2008
    Alexandria, VA
    Re: stage 2 or rs4
    yeah man, let me know how it goes
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    Re: stage 2 or rs4
    Vast Stage 3 clutch FTW.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Re: stage 2 or rs4
    like graham said, think of your future plans for the car and purchase accordingly
    Call Mike@VAST, tell him what you want the end result for the car to be and he will match with the perfect clutch based on your OVERALL GOAL for the car. They carry anything from a stock clutch up to a Stage 4/5 CM kit, kevlar wrapped, ect ect.
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Dec 01 2008
    Alexandria, VA
    Re: stage 2 or rs4
    alright ill give him a call, just call and ask for mike or what?
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    Re: stage 2 or rs4
    6 puck ceramic
    Dec 01 2008
    Alexandria, VA
    Re: stage 2 or rs4
    who makes a 6 puck ceramic?
    Aug 22 2010
    Qatar
    Hey Guys,
    I am planning to install a stage 4 (flywheel/clutch comco) on my RS4 (2007)...any recommendations, hints, advise???
    the car is superb, however, when push to its extremes, the clutch (stock) is smelling and the pedal is becoming hard...
    please advise
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    Spec3+
    EPL Stage 3 with a bunch of other crap.
    Veteran Member Four Rings NishadJoshi's Avatar
    Apr 22 2010
    Playa del Rey, Ca
    Whoa whoa whoa guys, you trying to make him poor? RS4 clutch? Stage 3?
    I suggest you look into CM FX400's or higher, Southbend and/or Spec's.
    derp.
    Veteran Member Four Rings imola's Avatar
    May 23 2007
    I recommend a Clutchmasters FX400 or higher if you plan for more power later on.
    sold :(
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    VAST stage III here and loving it.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    holy crap old thread resurrected!!!
    Clutchmasters fx850 twin FTMFW!!!!
    RS6 hybrids and corn
