Results 1 to 13 of 13
    Veteran Member Four Rings Dylan's Avatar
    Mar 28 2008
    Strange whirring noise
    As i start my car today, to come home from work, i notice a strange whirring noise coming from the front end.
    seems to be worse when turning, that's interesting...
    on the drive home, i pop it in neutral at a light, rev the engine a little, and it's still there, which means (to me) that it's engine and not diff or steering or brakes.
    get home, pop the hood (and notice my hood lifter is toast, having dripped its oil all over the front corner of my engine bay), get the woman to rev it up a bit while i use my bravestar-like hearing skills to try and pick out where it's coming from.
    to me, sounds like it's coming from the middle of the bay, between the drivers side and the engine.
    the only thing i can compare it to is the sound that's made when when you take a blade of grass between your thumbs and blow - of course, volume and pitch go up when you up the revs.
    i'm hoping to take it in later in the week, but i'm wonding if the AZ Lords of the Rings can toss some suggestions as to what it is.
    TIA
    BRING BACK GCC REP!!
    jason1st: If you just want a good job and to be able to take care of your family with a lot of security etc. Canada is a great place for that.
    If you want to crush your enemies, see them driven before you, and hear the lamentations of their women, then the United States is where you should be.
    (_|_) 4
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Re: Strange whirring noise
    Go to your car and crank it on, then walk to the rear right wheel and listen for the noise... It could be your Filter or Fuel pump... and in the case its your filter, I have made a nifty DIY for it!
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Don't drive it anymore, it could be a water pump or timing belt idler going out. If either fails your motor is toast, at least $1000 worth.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Mar 28 2008
    fuel pump even if the sound comes from the engine bay? i'm thinking that may be it, because when i get in the car when its cold and half-turn the key (which starts the fuel pump), i hear a not-normal sound.
    dirty, you've got me worried now! timing belt service/change was done about 30k ago, would that rule it out?
    thanks for your thoughts, folks.
    (_|_) 4
    Mar 21 2006
    Lakeland, FL.
    Never, new parts fail. Not trying to scare, just help.
    I'm back bitches!
    Mar 28 2008
    Quote Originally Posted by dirtybrd View Post
    i hear ya....
    i'm still thinking it's the fuel pump though, because of the weird noise at startup.
    (_|_) 4
    Mar 21 2006
    Lakeland, FL.
    You won't hear the fuel pump over the motor if you're standing in frt. with the hood up and it's running.
    I'm back bitches!
    Feb 27 2008
    It doesnt sound like this does it... Cuz if it does, I cant help you... mines made this noise since like the day I bought it... still dont know what the frick it is
    Mar 28 2008
    no, that sounds like an exhaust leak somewhere...
    i figured out what it sounds like - kinda like a manual car running in reverse, except i'm in drive and it's auto.
    (_|_) 4
    Mar 28 2008
    k, i don't think it's the fuel pump because the sound gets louder when turning.
    so:
    1 - sounds like a manual car in reverse gear, but is automatic
    2 - happens in neutral
    3 - gets louder when wheel is turned or engine rev'd
    4 - sounds like it's coming from the engine bay (no sound from the back when in the car and it's idling)
    any thoughts?
    (_|_) 4
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Power Steering... Check your fluid reservoir
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Mar 28 2008
    Quote Originally Posted by A4 Moda View Post
    i'll check and post results, thanks.
    (_|_) 4
    Mar 28 2008
    that did the trick - the simplest solutions are usually the best!
    thanks muchly!
    (_|_) 4
