Results 1 to 1 of 1
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Piping in a catch can on a 2.8? Do I want to splice into the Puck Valve pipe?
    yes, I did search, couldnt find a single thread on the 2.8 PCV system. From what I gather from the 1.8t threads you want to remove the PCV puck valve which is in line on the hose which runs to the TB and stops the back flow of intake air into the crank cases. I just want to verify that I understand this correctly. I want to splice into that hose, run a line to the catch can and then back to the TB right?
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
