    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Having problems cranking my 30V V6...
    It's a Passat, but same difference, right? My wife's 30V V6 does not want to crank cold. I have to tap the gas a few times while cranking it in order to get it to stay running. Otherwise it stumbles and dies. It seems like it's having a fuel issue, like it's not getting enough fuel until I give it extra with the pedal. After the initial start (from cold) and letting it idle for a few minutes it will run, drive and re-crank fine.
    I'm thinking either the fuel pump or fuel filter... any ideas? Anything else to help identify the problem? I have run fuel injector and fuel system cleaner through the system and am still having the same problem.
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: Having problems cranking my 30V V6...
    not sure waht its called on an audi but there are idle up valves on alot of cars that keep the idle high and run a little rich to warm the car up faster,
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    i'd go ahead and replace the fuel filter as its a relatively cheap and easy part to replace. then go from there.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    new battery maybe?
    __________________
    May 04 2008
    Columbia, SC
    Not battery... plenty of power, picked up fuel filter otw home today. Will put on tomorrow and report back...
