Results 1 to 6 of 6
    Jul 26 2004
    lake tahoe
    Serious issues Throttle body related.HELP
    Maybe someone can help. A few days ago i was driving on the highway and the car just shut off. I pulled over and tried to start it again with no luck. Finally it did start again, but would only stay running for a few minutes at a time. I got the car to my friends house and left it there until I could get vag com on it. When i ran vag com i got a Throttle Valve Control Module #J388 error code. I drove the car a few miles home but when it went over 1500 rpm on the road it would buck hard, and then drop down to 800 rpm. it continued to do this until i got it home. We have tried throttle body adaptation with no luck, taken apart the throttle body but nothing looked too messed up. Any ideas guys? I need my car up and running to get to work. Is it time for a new throttle body? anyone got on laying around they will sell for cheap? THANK YOU!
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Serious issues Throttle body related.HELP
    might help if we knew the year of your car.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    http://wiki.ross-tech.com/index.php/16891/P0507/001287???
    Basically check the wiring, connections, etc. It's possible your throttle body module died (meaning buy a diff throttle body assembly)
    Jul 26 2004
    lake tahoe
    my bad, thought it was in my sig. 98 1.8tqm
    Jul 26 2004
    lake tahoe
    Also would it be relevant that right before my car died on the highway I switched off my water injection? Maybe an electrical surge of some sort? thanks guys.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by freeskiwp View Post
    '98 is nDBW, meaning you don't have to do a throttle body adaptation. The only electrical stuff on your throttle body is the cruise control, which also works as a throttle position sensor.
    Check out your IAT readings and TPS voltage/% on VAG-Com. WOT should be ~85-90%, "shut" or idle should be >20%.
