Results 1 to 33 of 33
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    Question Audi Symphony SD Card Reader....
    Does anyone know how to format the SD Card for it to work??? I keeps saying the card is unreadable. SOME ONE HELP!!!
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Re: Audi Symphony SD Card Reader....
    Quote Originally Posted by B_Boy View Post
    Format it in a PC. And make sure it's only SD, not SDHC.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Jul 02 2008
    Pasadena
    Yah, make sure the card your using is not SDHC. Also, you can't have more than a certain characters for the file names. If the title of a song is too long, it just wont show up although it's on the card.
    Veteran Member Four Rings arce909's Avatar
    Oct 08 2008
    So-Cal
    Here's how to convert songs from iTunes into the SD card... Hope it helps
    http://askbobrankin.com/convert_itun...p3_format.html
    Veteran Member Three Rings CLEAR's Avatar
    Aug 28 2009
    2009 Audi A4 3.2Q Aruba Blue
    Pasadena, CA
    make sure it's 2GB non-SDHC or lower. I have some 4GB non SDHC bought from ebay, and it doesn't work.
    graphic designer - photographer
    Sold : Ducati DESMOSEDICI D16RR
    Junior Member Two Rings
    Mar 22 2010
    Philly burbs
    Here is the SD Association official SD formatting utility.
    Oct 08 2008
    So-Cal
    Quote Originally Posted by CLEAR View Post
    Thanks for the heads up!! I was just about to buy (2) 4GB SD cards from eBay, I guess I'll be buying the (2) pack of 2GB from bestbuy, for $20.... Thanks!!! What's the max amount of songs someone has fitted into an SD card?
    Active Member Two Rings 2SwiFt29's Avatar
    Mar 29 2010
    2011 BMW M3, Audi A4
    San Gabriel, CA
    2010 models can use SDHC now right? I think the firmware was update so it can read SDHC cards?
    2010 Audi A4 2.0T Quattro - Premium Plus w/ Navi - Ibis White w/ Black Interior
    2011 BMW M3 Coupe - Alpine White w/ Coral Red Interior
    Previous: 2006 Lexus IS350 Black Onyx w/ Sterling Gray Interior
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    I have a 4GB SD card from transcend it works just fine.
    NOTE, SDHC will def not work on my rev HW02, sw 0211 ver Symphony.
    Mar 22 2010
    Philly burbs
    Quote Originally Posted by 2SwiFt29 View Post
    The manual for 2010 says SD cards up to 32 GB are OK, so SDHC should definitely work. I recall seeing that 2009 models manufactured after February 2009 can use SDHC after firmware update.
    Oct 27 2009
    Miami, FL | Boone, NC
    SDHC works in my 2010...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Sep 20 2009
    Richmond
    SDHC for 2010 as well.
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    Panasonic 64GB SDXC Memory Card with Class 10 Performance, 22MB per Second
    Only $500
    2010 A4 Avant
    Dec 20 2009
    Canberra, Australia
    From MY2010, models equipped with Audi Symphony got Symphony II. IIRC, the major upgrade in Symphony II was support for SDHC and a 3.5mm input jack for AUX under the armrest. My wife's '10 car has both.
    Sep 06 2009
    TX
    Saw this on AuduFUS by or friend Local3...
    Upgrading Symphony radio ver 0211 to newest software ver (0310) increases SD capacity.
    http://audiforum.us/b8-platform/1007...html#post84427
    Anyone want to volunteer next time they are out the dealer to try the upgrade? I will, but prolly won't be to the dealer again for another six months to a year! (unless something pops up sooner...)
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    I have a 2010 witht he sd slot, SDHC 4GB, worked for almost a year and now it's unreadable, will try to reformat and see if that fixes. Thanks for the heads up on the Jack under the arm rest Da4banger, FTW!!!
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Oct 27 2009
    Quote Originally Posted by dA4banger.au View Post
    do you have both AMI and the Aux in under the armrest? I just have AMI and there is a blank filler under the armrest...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Quote Originally Posted by Tone-Dogg View Post
    That happens from time to time with removable media. A format will almost definitely do the trick.
    As does mine. You have an '09 as well?
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Senior Member Three Rings Speedybrit's Avatar
    Apr 15 2010
    IIRC you lose the aux jack if you get the AMI because there is a 3.5mm jack which can be used with the AMI
    Current Cars:
    2016 Sepang Blue S3 - Tech Pkg, Black Optics, B&O - Eurodyne Stage 2 ECU/TCU (Crackle Tune), Resonator Delete, CTS Intake, CTS Turbo Muffler Delete, CTS Turbo Inlet, USP Downpipe, APR Roll-Control Springs, APR Rear Sway Bar, and PowerStop Z23 Brake Kit
    Past Cars:
    2013 Monsoon Gray B8.5 A4 Prem+ 6MT
    2010 Meteor Gray B8 A4 premium 6MT
    2008 Subaru Legacy
    Oct 27 2009
    Quote Originally Posted by Speedybrit View Post
    that's what I heard too...
    I just don't really want to spend $50 on a 3.5mm AMI adapter...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Apr 15 2010
    I never ended up getting the AMI even though i really wanted it when i got my car. I now think i made the better choice because the MY10 SD slot supports SDHC cards which i put all my music i listen to on the card and presto i have the same ability to change music through my wheel/car as i would if i had AMI and the aux cable works just the same as the AMI 3.5mm jack would. Idk why i said all that but eh oh well thats my story/rant haha.
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    May 06 2007
    2020 Q3 P+
    Update Correction, I have a 2010 with a 2GB SD card, I reformated and works fine, also, I do NOT have the jack under the arm rest, there is a cut out for it but no jack.
    Jan 13 2011
    antwerpen
    amigo's i have used an SD card with 4 GB in my A5 2009 and it worked perfect, only i have much more music then 4 GB so i purchased the 64 GB SDXC card, but it does not get recognized at all
    does anybody know what to do?
    Veteran Member Three Rings Comp4k's Avatar
    Aug 10 2009
    Carlsbad, CA
    Quote Originally Posted by broodjebie View Post
    reformat the card to FAT32. It comes default in exFAT.
    Aug 04 2010
    Queenz/Westchester
    x2. 8 GB sdhc in mine, no problems
    Veteran Member Three Rings haroulli's Avatar
    Mar 06 2007
    Audi A6 C7 - BMW X5 F15
    East Coast
    I just got my SW upgraded at the dealer (I don't know what version, is there a way to check) but I don't have a SDHC to test just a 2gb SD. I also have the AUX in the armrest.
    Moonlight Blue 2018 C7.5 A6 2.0T S-Line Black Optics
    DEAD - Quartz Grey 2010 B8 A4 2.0T
    Sep 06 2009
    TX
    Check your VAG log of mod 56. Should tell you the HW & SW number on 3rd line. Mine is: Component: Symph3 Sirius H02 0211 - thats HW ver 02 with SW ver 0211.
    Jan 05 2011
    North Carolina
    Redundant but very cool this juke box. Mp3 discs work very well. Interesting it has 2 cards lots.
    10 gigs is a lot of music.
    The Ipod works wonderful with the set up on the prestige plus.
    Not sure I'd store music on the cards as I don't perceive them as steady. Cars environments are tough on cards. With my Ipod, if it fries, get a new one and synch it. Back up in 10 minutes.
    Great choices anyway you look at it.
    Dec 08 2015
    Tulsa/OK/USA
    Raising this thread from the dead...got 2011 s line q5 and SDXC 64GB card does not work. Called dealer and they told me that 2010 and up use just SD card and it will only play copyrighted music. Someone shine some light plz.
    Tried formatting and the file system is exFAT, but still no effect. Some say that 2010+ models support SDhc while others say it can only do SD card.
    If I'm in the wrong thread please feel free to redirect.
    Established Member Two Rings Anthony1491's Avatar
    May 15 2015
    Toronto, Ontario
    Quote Originally Posted by Muhtish View Post
    I'm pretty sure there's a 32gb limit on sd cards, i had to return my 64gb for a 32gb because I couldn't get it to work
    2011 Audi A4 Deep Sea Blue
    GFB DV+ - RS4 Grill - ECS Silicone Inlet Hose - Tint - AFe Filter - Ultra Racing Strut Bar - Eurocode HFC - Intercooler Soundbox Delete
    Steering Wheel Paddle Shifter Retrofit - Rohana RC22 19" 9.5 et45 - S4 Struts & Sway bars - Rev Motoring Springs - Custom Magnaflow Exhaust
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Somewhere along the line, Audi changed it's limits.
    I run dual 64GB SDXC cards without a hitch and I recall reading a handful of people that are running 128gb's.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Dec 08 2015
    Tulsa/OK/USA
    Red face
    Update: bought 16GB SDhc card from eBay and it arrived yesterday. Held my breath while I plugged it in. MMI recognized it and it's working fine.
    Although, dealer was not any help on this issue. Spoke with them and they told me it will only support a card up to 4 GB non hc.
    Quote Originally Posted by adamazing View Post
    This could be due to the fact that your Audi is not as old as mine. Mine is a 2011.
    Oct 12 2007
    Sacramento, CA
    I have a 2010 A4 w/ Symphony and
    I finally got around to getting a 64GB card (transcend sd/xc class 10 ) which I formatted to fat32 (you will probably need to find a fat32 formatting program) NOT Ex-fat, and it reads it, with just a few songs on it for testing it played instantly but when I loaded it with 62GB of music it takes about a 60 seconds to read and start playing on start up.
    Aidan
    2011 S4: 6 MT, Sport diff
    1990 CQ
    83 GTI
    1995 Land Rover Discovery 4.6
    It's all fun and games until you hear the German engineer say "spank me harder than a bottomed out suspension daddy"
