Page 1 of 7 123 ... LastLast
Results 1 to 40 of 259
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    WHEN will it END!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Foreshadowing. I drove my car and coolant gauge started acting up going to hot but then would go back to normal. I stopped to check and car wasnt hot so I continued on. It would do this every now and then. I got home and checked codes which said something about the temp sensor so I said ok I need to get a new one.
    The next night I decide to go driving with a friend and the gauge started screwing around again so I didnt pay attention to it and continued driving, I had went about 7 miles and all is well. I dropped down and pulled through 1 or 2 gears then cruised more. The gauge continued to move around and was in the H for part of the time and then the coolant light came one which I then figured was now acting up due to the gauge. I drove another mile and then pulled 3rd and 4th gear but the car started to not pull and felt week so I let off some and at this time I smelt coolant. I then hit the gas again and it felt like a coil pack had went and then the car died. I dropped the clutch with it in gear and it fired back up but still no power, I drove another 3/4 of a mile to the off ramp and it died again and then as I rolled up to the light smoke began to pour everywhere.
    I popped the hood and coolant had sprayed everywhere. The upper radiator hose that connects to the hard pipe that runs over the intake manifold had popped off. I tried to start car again but it wouldnt. My friend and I pushed the car to gas station and left it there over night. I went back next day and pulled the plugs and there was coolant in each cylinder so I figured I must have blew the head gasket or warped the head. I checked the oil but no coolant in the oil. I filled coolant up and dried off plugs and tried to start again but no good. Took out plugs and once again little bit of coolant in the cylinder and on the plugs.
    I went and got a uhaul trailer and towed the car to my house. I took the intake manifold off just now and a little coolant dripped out of it and some was down on top of the valves. I was a little confused by this wondering how the hell there was coolant in the intake. I continued to take the front end apart and all that good stuff since I was gonna take the head off to have it checked.
    I disconnected the intercooler pipes and about a 1/2 cup of coolant came pouring out of the piping and intercooler! I now assume that the seals or jacket whatever it is on the coolant side must have went bad or something allowing coolant to go from the coolant chamber in the center of the turbo and into the compressor of the turbo and into the intake system. Does this make sense to anyone else? Is this possible like oil leaks through on the other side if the seals go causing it to go in the exhaust. Needless to say this sucks big time.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    Re: WHEN will it END!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    yikes
    Feb 17 2005
    Sarasota, FL
    Ahhhhhhh fun huh? I told ya shit happens, its not the walk in the park you thought it was going to be!!!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by A4 TSCHUSS View Post
    Most likely overheated the motor and blew your head gasket for starters. Clint did this and he's onto a new motor now thanks to running WOT on an overheating motor (amongst shitty machine work on the bottom end for the first build).
    Why your IC pipes have coolant in, I do not know. Might want to check the CHRA on the turbo like you are thinking...
    Sorry to hear about this. Let us know if you need anything.
    It is tough to 'say no' and not drive the vehicle when you think something's amiss. Look at me, I was going WOT with a blown exhaust gasket and a faulty serpentine belt tensioner this past weekend. Last night I put the car in the garage and ripped 'her apart to fix the problem. I've waited too long to break something more. Gotta cut it off at the pass.
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    only thing is there is no coolant in the oil so that is why I think the head and gasket are fine but I could be wrong. I am thinking it is just the turbo that is leaking coolant somehow into the intake track.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Hmm. Guess I'd suggest looking at the turbo first before pulling the head off? Might behoove you to pull the intake manifold off and look down the intake ports on the head as well.
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    I did take it off that is when I first saw coolant when it dripped out of the intake mani and that is when I got confused. There is a little coolant sitting on the top of the intake valves
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Which probably got there through the FMIC and TB if you're seeing coolant on the turbo exit now that I think about it and have read your first post over again. Hmm.
    Only thing I can think of as to how it got there is somehow you overheated the turbo and blew the jacket like you are thinking? Is there any way to verify this without sending the center section to ATP or Garrett?
    -Doug
    Feb 17 2005
    Sarasota, FL
    Makes sense but the oil seals are typically way more heat sensitive. Obviously your motor was running at an extremely hi temp coolant wise which would have transfered to your oil temp as well
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    This is one main reason why if the coolant gauge or light goes crazy, i turn the car off and figure it out...i would bet it went through through the IC to the TB if ur seeing coolant there, Time for some trouble shooting....Good luck
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Feb 17 2005
    Sarasota, FL
    Just asked Adrian if blown coolant seals would allow coolant into the charge pipe, he laughed and said hell no. The only way coolant in the IC was possible is from the turbo sucking it up through the intake. If you had coolant everywhere in your engine bay, pretty good chance you could have sucked it up.
    Apr 24 2005
    E55 AMG, CTS-V
    no way it sucked up coolant. My filter is way down on the passenger side up against the fender under the head light and it wasnt wet. And also it wouldnt be able to suck that kind of water into the intake track unless the filter was submerged not just some water spraying around on top of engine from the hose. Way on that side of the engine and especially down low there is not really much sign of coolant like there is all on the driver side.
    ~David~
    CTS-V 9.6@148
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Remove all the coolant from the cylinders and compression test it to see if the headgasket is blown or not.....
    -Sami-
    Apr 24 2005
    E55 AMG, CTS-V
    yeah I am gonna compression test, I need to borrow a guage though from a friend.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    See where my filter is. And like I said this is also under the headlight so that coolant would have been amazing to get around all the obsticles and over to the filter. And there is no coolant residue (stickyness) on the MAF or filter like everywhere else.
    ~David~
    CTS-V 9.6@148
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    I can't read this thread. It make me cringe!
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    check your turbo. something might have happend with the coolant passage causing it to leak into the outlet of the turbo and into your intake manifold etc.... it would explain coolant in there and also loosing coolant causing the higher engine temps.
    for sure do any test to check for warpage from the high engine temps.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Feb 17 2005
    Sarasota, FL
    Thinking about it, the coolant jacket is not at all connected to the shaft of the turbo, its just a seperate housing surrounding the center section of the turbo. There isnt anything there to fail as you are suspecting
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Pressurize the coolant lines to the turbo and check to see the the seals are allowing coolant to leak into the compressor...
    The only thing is that if you have that much coolant get into the intercooler, hydrolocking is a possibility.
    Apr 24 2005
    E55 AMG, CTS-V
    The engine never had a problem spinning over and all the intake valves were holding coolant/gas on top of them so they arent bent.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by A4ringedONE8T View Post
    Bob @ qed power said the turbo doesnt have coolant seals and is a jacket and cant leak too like you are saying Shawn. I am so confused how this damn coolant is in my piping!
    ~David~
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    when you toasted the headgasket coolant could have gone through the head....
    this is what Mtbrider did and he had coolant all in his catch can
    - Clint
    Feb 17 2005
    Sarasota, FL
    If the headgasket goes typically he would have coolant mixed in the oil as well which he does not
    Apr 24 2005
    E55 AMG, CTS-V
    through the head where? And how would it get all in my intercooler/piping. Unless I am crazy the only way for the coolant to be in the intake track is through the turbo on the compressor side. Now how does coolant get in there if it isnt sucked up through the intake such as would be the case if I went through a deep puddle submerging the filter. Since that isnt what happened then how does the coolant enter the intake track (intercooler and piping) and then I assume get blown in to the cylinders through the throttle body down into the intake manifold.
    And like Shawn said, I have clean oil so no coolant/water in my oil. I am gonna do a compression check a little later too when I get the gauge.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    All signs are pointing to the turbo.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jan 25 2006
    A4 2.0T
    MD
    Puzzled.
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by A4 Moda View Post
    Yes but at the same time people are saying it isnt possible to have coolant leak from the coolant jacket into the compressor housing which I dont know to be true or false. In my mind I see that coolant could leak through from the jacket into the compressor since the shaft of the turbo goes through there so why couldnt it leak there if something wasnt right to seal out the water, but then I am told there isnt a seal but then how does the shaft go through into the compressor from the water jacket with no seal.
    ~David~
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    ahh true, that might account for the plugs but not the IC piping...
    - Clint
    Apr 24 2005
    E55 AMG, CTS-V
    now that I look at a turbo diagram cut out I think the water jacket is completely seperate and the shaft doesnt go through it because it is on the outer side of where the shaft runs through and there is an oil seal on both sides so only oil could leak into the compressor. I think that pic is of a oil only turbo though.
    ~David~
    CTS-V 9.6@148
    Jun 11 2005
    You haven't much luck in the past with your center cartridges man. I wouldn't look past it.
    You think that might be related? Is your water pump F*ed? That's why you've blown your center cartridge twice on the GTRS?
    And now again on your BAT?
    2003 1.8T
    Jan 25 2006
    A4 2.0T
    MD
    No oil seal on GT turbo.
    Apr 24 2005
    E55 AMG, CTS-V
    This diagram I think would show more how the coolant passage is seperate from where the shaft is which kills me since I dont see how the coolant would get in the intake any other way!
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by Don Supreme View Post
    how do you figure? I blew the oil seals twice on my gtrs.
    ~David~
    CTS-V 9.6@148
    Mar 31 2004
    CA
    shit man... hard to say with out really inspecting that shit. I would have thought its turbo related with coolant being in the intercooling piping...
    keep us posted and inspect the shit out of it.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Instead of listening to everyone and making your head spin in multiple directions leave your computer and go do your own troubleshooting around your engine bay. Inspect everything and come back with the results. We'll then go from there. In the meantime anyone and everyone will continue to suggest things from your turbo jacket to landing on the moon. Who knows what really happened......
    -Doug
    Dec 06 2007
    time for a new motor or car david, u've had tons of headaches with this one man, don't know.
    really check the turbo, could be Bob made the whole thing up for starters. Check the turbo, pressurize the coolant lines u'll find out where it is coming from, i say run a whole new set of coolant lines throughout the engine bay made of silicone after the issue is fixed this way u prevent any further issues. Check ur water pump too.
    -Kirk
    BetaAlphaTau Member #58
    Jan 25 2006
    A4 2.0T
    MD
    You didn't blow 'oil seals' you blew something else. The "seal" on the compressor side is to stop an air leak and the other seal is there to stop the exhaust gas from mixing.... As I undestand it. If you don't believe me than you can call up a Master Level Garrett Distributor and ask them about oil seals.
    I have no idea how coolant got into the charge pipe.
    Apr 24 2005
    E55 AMG, CTS-V
    Did a compression check and have 0, 30, 15, 160. Guess I have a bad head gasket and or warped head.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Ouch!
    Time for ARP head bolts so you can re-use them.
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    The proper term was turbine side "piston ring" and "bearing retainer" that was the caused failure Atp turbo told me after taking the turbo apart and checking/testing everything.
    ~David~
    CTS-V 9.6@148
