Results 1 to 20 of 20
Thread: Air Bag Light
    Senior Member Three Rings jrodpikap's Avatar
    Oct 23 2006
    2004 A4 USP 1.8T Stage 1 & 2000 A4 1.8T
    Conshohocken, PA
    Air Bag Light
    Mine came on yesterday for no apparent reason...any easy way to "reset" it or fix whatever the cause for the indicator is?
    Oct 23 2006
    Conshohocken, PA
    Re: Air Bag Light
    Bump...anyone...it's gotta be a simple fix right?
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: Air Bag Light
    Use a vag-com to see what code it is. You can then clear it and see if it comes back. I've heard of wires coming loose under the seat and causing this, but depends on code
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Jul 31 2007
    99 Audi A4 2.8 Quattro
    peg city
    Re: Air Bag Light
    theres a few things with the airbag sensor. First , you should scan it, commonly its a high resistance or something, a pretty common problem on b5's. But there is a simple fix. Simply take out the connector, located underneath the passengers seat and clean it, and then reconnect it and zip tie it tightly shut. The airbag connector is very sensitive for whatever reason. Ive done this and it works!
    Oct 23 2006
    Conshohocken, PA
    Re: Air Bag Light
    Fantastic...on the passanger seat is it under the front or back of the seat? Any certain color I should be looking for or is it the only connector under there?
    Jul 31 2007
    peg city
    Re: Air Bag Light
    its under the front of the passenger seat, i dont remember exactly which connector it is, could be a yellow 2pin? but im just guessing.
    Jul 01 2008
    Minnesota
    Re: Air Bag Light
    You still need a vag to reset it..
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Air Bag Light
    Quote Originally Posted by kmongru View Post
    I believe it is purple.
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    Re: Air Bag Light
    Argg I have the same issue, but for a different reason...
    A sidewalk hit and detonated the side drivers side airbag and now the light wont go away
    I even tried to vag com it I think I need to replace the damn thing.
    Veteran Member Three Rings hernandez3011's Avatar
    Mar 21 2008
    United States
    Re: Air Bag Light
    press the center of the steering wheel to honk the horn. If the horn doesn't work you need a new clock-spring. I had a airbag light last week and figured out the problem after much research.
    May 18 2008
    SOOOOOO Cal
    Re: Air Bag Light
    yeah thats what Im told I need also, but my mechanic doesn't or can't do it and says I should take it to dealer
    Mar 21 2008
    United States
    Re: Air Bag Light
    I personally wouldn't take it to the dealer because they will rape you. I heard it's like a $300 part, I got lucky and bought mine on ebay for $25 and replaced it myself. It's not that hard. The most important thing is to adjust/align it correctly or you will snap the coil inside again.
    *edit*
    Here is a link to one that is for sale now. $35 shipped.
    http://cgi.ebay.com/ebaymotors/_Car-...4506.m20.l1116
    May 18 2008
    SOOOOOO Cal
    Re: Air Bag Light
    ah cool, and you did it yourself... wasn't too hard?
    Mar 21 2008
    United States
    Re: Air Bag Light
    Nope it took like 30-45 min. You have to be careful when centering the ring. The replacement one may have been removed at a different position. It's kinda hard to explain but you will see when i'm talking about once you attempt to install yours. I wish you were local, I would definately help you out.
    Oct 23 2006
    Conshohocken, PA
    Re: Air Bag Light
    Quote Originally Posted by hernandez3011 View Post
    And if it does honk...then you just need to reset it with a Vag?
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Re: Air Bag Light
    You should scan it either way. If your horn does honk than that could mean it's a different airbag throwing the light rather than the one in the steering wheel.
    Jul 12 2007
    Massachusetts
    Re: Air Bag Light
    The module itself can go bad, which is what happened to me. Its a $400 part where the module gets sent in to be rebuilt.
    2020 SQ5
    Mar 21 2008
    United States
    Re: Air Bag Light
    Quote Originally Posted by jrodpikap View Post
    If it does honk it is not the clockspring, it could be the airbag wiring found under the seat as suggested earlier.
    Yes brand new it is like a 300-400 dollar part but you can buy a new clockspring on ebay for only 30-$40.
    Oct 23 2006
    Conshohocken, PA
    Re: Air Bag Light
    Well the horn honked with no problem, so it's not the clock spring. I'll have to check the wiring under the passanger seat. Looks like there are two connectors, one Yellow and one Purple I believe. I assume one is for the heated seats and the other for the Air Bag.
    Can anyone confirm which is for the Air Bag? And should I just use Alcohol and swab the connector down to clean it up?
    May 18 2008
    SOOOOOO Cal
    Re: Air Bag Light
    *edit*
    So this should fit our cars no problem right? I have a Tiptronic so not sure if I need another clock spring... I want to do it as soon as possible I can't be driving with out my horn!
