Results 1 to 7 of 7
    Registered Member Two Rings
    Nov 27 2008
    2001.5 Imola s4
    VA, MD
    ok so i think i am going to shoot my car
    is there anyway that a burnt out element in the front right running light can cause the rear right running light to not come on.
    this is driving me insane
    2001.5 S4
    Darintake Mod, 18" Unknowns, Nitto 225x40, Dual Forge 007 DV's
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: ok so i think i am going to shot my car
    Well, the simple answer is not technically, no. Meaning if one goes out, the other doesn't have to go out as well. But you could have blown a fuse.
    --Adam
    ps - I edited your title ... It's "shoot," not "shot."
    Have questions? E-mail me.
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Re: ok so i think i am going to shoot my car
    They are all wired in a weird series.
    I had the wrong wattage bulb in my taillights, and it caused all sorts of problems in both the headlights and taillights.
    Nov 27 2008
    2001.5 Imola s4
    VA, MD
    Quote Originally Posted by HotSauce View Post
    what wat do you use b/c i got the bulb from a parts store.
    is there a dif between 2001 and 2001.5
    what other problems did you have?
    did it mess with your abs at all?
    2001.5 S4
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    the fuse is out.... the drive side parking lights are on a seperate fuse from the pass side parking lights
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Sep 23 2007
    I have this same problem with my car. My passenger side tail running light is out as well as the front passenger side city light. The funny thing is when i press the brake pedal the front city light comes on like. Any one know what is causing this?
    Nov 27 2008
    2001.5 Imola s4
    VA, MD
    Quote Originally Posted by S4 Dan View Post
    thanks ill try that when i get home, does it say it on the fuse cover chart?
    2001.5 S4
