    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    I Need To Find A Tach Signal
    My tachometer is busted and im trying to find out if i can pick up a tach signal from the fuse box and if so which plug to run a standalone tach. Or anywhere else for that matter. Hooked it up to vag and the rpms are off, i.e. showing 6000 @4100 actual. They vary at different rpms. Any leads are appreciated. Thanks
    00 C5 2.7t //Stage 3//
    Nov 15 2006
    00 S4, 99Cobra, 54BelAir
    The Milky Way
    Re: I Need To Find A Tach Signal
    You can pick up a digital tach signal in the wiring harness behind the instrument cluster.
    There was a post on AudiWorld a while back about somebody finding an analog tach signal for the purpsoe of a remote starter. it was in the sheath of wires going to the ecu.
    Hope that helps a bit.
    Sep 02 2007
    Baltimore, MD
    hopefully thanks
    Senior Member Two Rings EuroFreak's Avatar
    Jun 08 2009
    Left Coast
    Did you ever find the correct wire? I'm looking to install a shift chime/buzzer and I also need the tach signal for this.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    i just went through this trying to hook up a zeitronix on my setup...right at the ECU harness.. green blue wire at pin number 37 i do believe....
    RS6 hybrids and corn
